Results 1 to 8 of 8
    serbia
    Default blaupunkt woodstock dab 54
    hi to all i need help with decoding this unit
    i have not original sd card but i buy a new one
    where i can find a master code for programing a new sd card
    and how i can enter that code
    inside is 95640
    bp4708 5 4949525
    7644708310
    thanks in advance
    Ukraine
    Quote Originally Posted by delboyrodney View Post
    inside is 95640
    bp4708 5 4949525
    7644708310
    thanks in advance
    Card is not SD, it's similar to MMC. But it's not MMC-card, so you can't by any MMC-card and use it as keycard. You must have keycard from Blaupunkt!
    serbia
    i found somewere on internet description of procedure
    what are you must doing if you lose the card
    that procedure describes
    enter new mmc card and than turn on radio with presed 1,4 buttons
    and then enter master code ,then your card will be programed and your radio after that works normaly
    this description of procedure is not precise but that's the point
    if somebody know something about this procedure i would like to hear it
    thanks for answer
    thanks in advance for new idea
    best regards
    Ukraine
    thanks for answer
    best regards
    Yes, this procedure is not precise :
    1. the main - you must enter not new mmc-card but any mmc-keycard from Blaupunkt! It's only look like mmc-card, but has only 512 bytes size (bytes, not kbytes!) and different logical organization. So you need MMC-keycard from Blaupunkt.
    2. I think master-code of your radio is 6295. You can test it without card.
    serbia
    thanks for engagement
    tell me one more thing
    how can i enter the code
    what button i must press before entering the code
    thanks in advance
    best regards
    Ukraine
    thanks in advance
    best regards
    From manual for the similar models Los Angeles MP72 and Toronto MP73:
    Lost or damaged KeyCard
    If all the unit’s KeyCards are damaged or lost, you can prepare a new KeyCard. You can acquire a new KeyCard from your dealer.
    Preparing a new KeyCard / entering the master code
    If you no longer have a valid KeyCard for your unit or you want to prepare a second KeyCard:
    - Insert a new KeyCard that the unit is not yet “familiar” with.
    - Close the control panel.
    - Switch the unit off if it is not already off.
    - Simultaneously press and hold the TUNER button 12 and the top left softkey 4.
    - Switch the unit on using button 1. “0000” appears in the display.
    Enter the four-digit master code that is printed on the car radio passport as follows:
    - Enter each of the master code’s numbers using the joystick 7. To do so, repeatedly press the joystick up or down until the required number appears in the display.
    - You can move the input cursor by pressing the joystick 7 to the left or right.
    - If the master code is displayed correctly, press the joystick OK button
    The new KeyCard is accepted as soon as the unit switches to playback mode and “KEYCARD OK” appears briefly in the display.
    serbia
    thank's a lot
    i will try this in monday and i will post reply here
    serbia
    i was tried my blaupunkt without succses
    when i was enter the master code he show me please wait than card not ok
    when i tried another code then show me code error
    when i tried without the card than again show me card not ok
    thanks my friend for engagement
    best regards
