Results 1 to 15 of 21
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Default How to play XBOX 1 Games on XBOX 360 Flashed with ixtreme
    Note: If the xbox 1 game u r converting is less then 4.5gb then its a single layer game, so use this procedure 1 and convert it to play on xbox 360. If the xbox 1 game u have is greater then 4.5gb, then its a dual layer game, eg:halo 2 etc... if its a dual layer game follow procedure 2:
    PROCEDURE 1:
    Software needed:
    1.XDVDMulleterSS,PFI,DMI files and Video Partition(SS file is in Security Sector folder, DMI and PFI are in Stealth folder) - Download it frm here: MEGAUPLOAD - The leading online storage and file delivery service
    2.ISOBUSTER - MEGAUPLOAD - The leading online storage and file delivery service
    3.Alcohol 100% - MEGAUPLOAD - The leading online storage and file delivery service
    Step 1: More or less the process needs approximatly 15GB of free HDD space Now run Run XDVDMulleter ( use one that I provided ) select 'View ISO details' and click 'next'. From 'Load ISO Folder', browse and load the XBOX.iso ( I will use Star Wars KotOR II.iso ) After you load XBOX.iso it should look like this
    Step 2 :Now you insert video partition from folder ( there are 3 partitions in folder try every one of them ) that you downloaded from link tht i posted above
    Step 3:After you are done with inserting video ( boxes should be checked [1] on mulleter as is show on pic ) insert SS PFI and DMI files into .iso
    Step 4: After you are done inserting all dose files mulleter should be like this
    Step 5: iXtreme box its not checked) Click next to go back to the main menu, select 'Build/Rebuild files in ISO' and click 'next', select and load the XBOX.iso as before, click 'next' and choose 'Create a DVD9 ISO with zero padding (Xtreme compatible + Video)',
    Step 6: 'next' and XDVDMulleter will check if the XBE is valid, click 'next' until you get to 'Make ISO' and click on it. You don't need at this time to load the ss.bin, dmi.bin or pfi.bin files After XDVDMulleter has finished,you should have another .iso (in my case its Star Wars_ KotOR II_mulleted.iso )open 'My Computer' and right click on the virtual drive created by Alcohol 100% to mount the XBOX_Mulleted.iso
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Step 7:Run IsoBuster and select the virtual drive Click 'Options' and then 'Communication', a new window will pop up, click on 'Read Settings' and set everything to 1 and click 'OK'
    Step 8:Right click on the main folder, on the left window, and select 'Extract DVD <Image>', then click 'User Data (*.tao,*.iso)'
    Step 9:Name the file and use .iso as extension, Don't press 'Save' yet From 'My Computer' right click on the virtual drive and mount the XBOX.iso, (Star Wars KotOR II.iso)
    Step 10nce it has loaded it, go back to IsoBuster and click 'Save'. After a while IsoBuster will report an error. Just select 'Replace with dummy data' and 'Always apply selection', click 'Selection'
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Step 11: When IsoBuster has finished, it will ask you to delete some files, (Choose 'No')and to save the .cue file. (you don't need it) After IsoBuster is finished you can delete XBOX.iso and XBOX_mulleted.iso DON?T DELETE .iso THAT YOU MADE WITH IsoBuster.iso Now let's run again XDVDMulleter and select 'Build/Rebuild files in ISO' click 'next' and load from 'Load ISO Folder' the IsoBuster.iso (Star Wars KotOR II IsoBuster.iso) in the 'Use Current Folder', 'next' and select 'Create a cloned DVD9 ISO (Xtreme compatible if the source is good)'
    Step 12:click 'Yes' when prompted. In the next window load the ss.bin file from your folder and click 'next', so for the dmi.bin and the pfi.bin files, click 'next' and press on 'Make ISO'. When it's all done, check with XDVDMulleter the .iso to see, that it has become an iXtreme compatible image. Now just burn it as x360 game with CloneCD or IMGBurn and play Note: This works 100%
    PROCEDURE 2:
    Step 1: You will get xbox1gamename.iso file, i assume tht it is a xbox 1 game.
    Step 2: Now create .dvd file for the .iso file you have,To create .dvd file, Open Notepad and type:
    Layerbreak=1913760
    xbox1gamename.ISO
    Replace "xbox1gamename.iso" text in the notepad with the name of the .iso file (xbox1gamename.iso, eg: if u hav halo2.iso file then put halo2.iso in the notepad also). After typing this. Save the notepad as xbox1gamename.dvd near the location of xbox1gamename.iso, for eg:halo2.iso and halo2.dvd
    Step 3:Follow the same procedure as you write normal xbox 360 game and write it.
    Note, i used differant software than alcohol to mount the image, daemon tools was used. Iso buster is not on megaupload, i used the free version.
    Thanks to orginal poster.
    V.I.P. Member cgscott's Avatar
    Jul 2008
    cmd
    Yes i seen that. Good to add to this site though.
    Patience is a virtue.
    Aug 2010
    Quote Originally Posted by cunny View Post
    PROCEDURE 2:
    Layerbreak=1913760
    xbox1gamename.ISO
    hello!
    thank you very much for this quite efficient help! i have a problem, however. my problem is, that after all the steps, and after i burn the image, my x360 sends a window of an error, and i can't imagine why. could it be, that i try an xbox classic iso (kotor 2), which is ntsc, to be played by my x360 which is pal? pls help me with this rather annoying problem, as how to make from an ntsc xbox classic iso a pal one? if it's not possible, than pls, upload somewhere your iso (the one from the steps, with witch you made the example with), as i have seen that its region is eu (pal)! it would be much appreciated!
    DK Veteran djjwdubz's Avatar
    dudley west midz
    does this mean it can play all the games? not just the listed games from the xbox site. every game
    Jul 2008
    cmd
    Quote Originally Posted by Imperator View Post
    hello!
    You have to have the game for your region. No ntsc etc will work on a Ixtreme modded console the only way to unlock region is by chip or Jtag.
    DK Veteran johnboy1974's Avatar
    glasgow
    thanks for the time and effort you put into this cunny another great upload mate.
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Quote Originally Posted by johnboy1974 View Post
    Thanks for that mate, but all credit for this goes to the original poster. For those interested, there is another method to get them working.
    Dec 2010
    tnx m8 u helped me allot
    Where are the links ?
    Feb 2011
    i did everthing that u said and it was good but when i try to play the game it says that a update is requered when i try to install it it says is that it is up to date help plz
  13. #13
    Feb 2011
    Default XBOX 1
    anyone have xbox 1 games
  14. #14
    Apr 2013
    ok iv followed this to the letter, the only issue im having is when your extracting through isobuster and meant to get hte error message , i dont get that, is that an issue or am i doing something wrong :/d
    as when i check the final image random padding and ixtreme compatible is not ticked
  15. #15
    dudley west midz
    I never even tried to do this.
