Results 1 to 8 of 8
    DK Veteran scotcruz's Avatar
    Sep 2010
    S C O T L A N D
    Question peugeot servicebox installation
    Hi folks,
    trying to install Peugeot Servicebox and Sedrap on my XP Laptop as I cant view the diagrams on my Win7 Desktop..
    In the installation, its not giving me the option to install it as a terminal. It just goes straight to install and then after few hours when the installation finishes. I am not able access servicebox. Also it does not ask for 3 or 4th DVD. It doesnt install Servicebox and only install sedrap...
    has anyone else experienced this?
    please advise..
    Liteace's Avatar
    Mar 2009
    On a rock
    Maybe this will help:
    http://www.digital-kaos.co.uk/forums...ctions-165742/
    its always best to do a search 1st, it's an amazing place is DK
    Sep 2010
    S C O T L A N D
    Quote Originally Posted by Liteace View Post
    thanks mate, I had looked at it already... hence why I posted !
    Member maarksparky's Avatar
    Jun 2008
    Quote Originally Posted by scotcruz View Post
    Lol... that's what you get here mate... someone smart thinks you are stupid..
    Anyhow, I had the same problem... from what you have posted it sounds like you have burnt the software on cd/dvd...
    In that case, restart run setup after switching AntiVirus off
    Good luck
    Sep 2010
    S C O T L A N D
    mark, y're a star
    I had bitdefender disabled it and the input the DVD and hola !!! now gave me the option to install it on to a terminal..
    couldnt thank you enough mate.. cheers had a job stuck and wanted to check the wiring diagrams..
    Sep 2010
    S C O T L A N D
    guys... need help.. I have installed the 9.2011 version of Peugeot Servicebox Backup and activated it ok. Sedre works fine but I am unable to access DocBackup and get the following error..
    Please can someone help?
    Un probl?me technique est survenu.
    Veuillez vous reconnecter ult?rieurement.
    A technical problem occurred.
    Please retry to connect later.
    Un problema t?cnico ocurri?.
    Revise por favor para conectar m?s adelante.
    Ein technisches Problem trat auf.
    Versuchen Sie bitte wieder, um sp?ter anzuschlie?en.
    hi folks i know its old thread
    just had to reload all my programs as hard drive went down, i getting the same error as above, sadre works as normal
    I think i must have pressed wrong button as backup Doc loaded the web page but can't see how i fix it
    managed to fix it using this fix
    sorry for the format style, copy & pasted
    "I was having the same problem, sedre backup running and docbackup showing error
    I solved by copying all DLL's from : C:\ProgramFiles\SEDREAP\Firebird to the C:\ProgramFiles\DocBackupAP\Firebird
    Just copy and paste all .dll files from one folder to another and when prompted replace the files"
    one thing i've never seen before when starting docbackupAP is flashing icon on the taskbar, also program starts up a lot faster for me now
