I have a soft mooded WII 4.2e and i need to update to 4.3, to play the game Naruto Shippuden : Dragon Blade Chronicles. The game dosn't work without the latest system update, and i cannot update my WII by online system update, because i risk to brick it.
Thanks for this will try it on my wii now
I just want to make sure that this will upgrade my wii safely so that i don't brick my wii. Will this get rid of the message system needs updated when i put a wii game in or not. Please let me know. Thank you.
If all you want to do is stop that message coming up, just install priiloader / preloader and enable, block online and disc updates in the hacks menu.
hi
used this update yesterday but i think iv done something wrong followed instructions it loads all the way through till the end then i get system install error 1010 press any button to restart your consul but i cant acsess the wii system any more i did some research into error 1010 and it seems that this a memory issue not enough blocks free on the wii but i cant get into delete any now that the system is locked i can load games and HB channel via preloader and my sd/usb drive work ok but cant start up wii system menu have i bricked it or can it be fixed or undone im a novice to this and should have done more reading before i started i dont have a backup nand either thanks for any help on this in advance.
cheers johny48
oops try this AnyTitle Deleter/AnyTitle Deleter MOD - WiiBrew put it in your apps folder and start homebrew with priiloader and delete a load of rubbish you dont wont untill you have more that enough blocks for the update, then try running it again
thanks for that ck-ok after i deleted all the game saves and titles it ran ok and installed the 4.3 update again THANKYOU very much.
cheers johny48
do i have to delete any of my old soft mod
Sorry about the noobness of this question. If I upgrade to 4.3u, will this brick my wii. I did 3 upgrades about a year ago & didn't print the directions; these directions are no longer available. I am using Configurable USB loader no web browser on wii... My shop channel is stating that i need to do a system upgrade to shop. My connect 24 is not on. Also it seems that i've messed up my homebrew trying to update it from the web-update.
Any help would be greatly appreciated. thanks in advance
if you have done a online update then your mod will no doubt be screwed, and you will be on 4.3 check by clicking on the wii sign in bottom l/h corner and looking at the top r/h corner on the next screen.
if your on 4.3 and your homebrew channel is not working then your gonna need to follow this http://www.digital-kaos.co.uk/forums...-3-mod-157379/
if all you need to do is update the shop channel then follow this
http://www.digital-kaos.co.uk/forums...er-v20-173066/
So this will help me safely upgrade to version 4.3, as of September 7, 2010?
Just registered here to try out this updater as i have done all other directions i can find to fix black ops online.
I am still getting an error i have read others have had.
I have the game running within ios249 on USBloadergx or configurableUSBloader and i have installed the ios 56 along with the new rev 20 shopping channel and have access to the current shopping channel and have been successfully able to download and play a demo through wii shopping channel on my 4.2u system but still have error with black ops online.
The error i have is that i can run the game fine but when I attempt to connect to multilayer to update it just sits there, connecting to Nintendo wifi forever, never gets to the option to download the update.
Other games i have that run nintendo wifi net like conduit and brawl are able to connect to wifi net fine but black ops still stuck.
So im going to try to update 4.2u to 4.3u and see if that changes anything.
Any other ideas or directions i may have missed would be greatly appreciated.
Here is verbatim the directions i followed to get my black ops to where it is now, like i said i get the game running fine and can acess shopping but still cant connect to Nintendo wifi within black ops.
All Directions enclosed below are credited to thier original posters and have been copied into this txt instead of outside links.
Part 1: (original poster, Gaiaknight)
First we are gonna we are gonna install Ciosx20b
Online Installation
1. load up HBC and launch the installer
2. select 249 to use for installation (if you are upgrading if not use a patched ios36)
3. select 57 to use as the base
4. Install to slot 249
5. Choose Network Installation
6. now if everything went right your done congrats
Offline Installation
1. place the wads gotten from the ciosx20b thread and place them on the root fo your SD or USB
2. load up HBC and launch the installer
3. select 249 to use for installation (if you are upgrading if not use a patched ios36)
4. select 57 to use as the base
5. Install to slot 249
6. Choose Wad Installation
7. Enjoy and your done
Now to instal hermes 5.1
*Now before installing hermes 5.1 remove all Gamecube memory cards and controllers and make sure you have a patched ios36 or ios236 or a previously installed hermes cios*
Online Installation
1. Load HBC and select the hermes 5.1 installer
2. select either 36, 236, 222(only if its installed already)
3. select either 223 or 224 and choose base 57
4. It will now begin to download the files when prompted to hit 1 to install
5. if no errors happen and it reboots back to HBC you are done
1. place the offline files obtained in the hermes thread in a folder called ios on the root of SD or USB
2. Load HBC and select the hermes 5.1 installer
3. select either 36, 236, 222(only if its installed already)
4. select either 223 or 224 and choose base 57
4. It will now begin to install
Part 2: (Original Poster Egurgle)
donwload miixpress from my signature.
extract it to c:\miixpress\
load it and type i do and hit ok
clickk channels
choose wii region and choose shopping channel. miixpress will download correct ios56 to you.
get Wiimod too.
then click transfer to sd buton.
load wiimod from hbc and you will get ahbprot enabled if you are using hbc 1.08.
then press right, and install ios56 first. after a successfull ios56 installation, install shopping channel wad.
If you dont have hbc 1.08, press left in wiimod and choose any ios 200+. then press right and install wads above as i described.
thats it,, let me know if worked
Once again thanks for your time everybody.
