Hi to all
I found a very good manual for passat B5 ABS unit repair, I try it and it realy works. Maby it helps for someone to save money
AUDI A4 A6 A8 VW passat B5 Bosch 5.3 ABS ECU MODULE REPAIR MANUAL by VOLTas | eBay
Hi to all
I get this message from the link "This listing (270964070696) has been removed, or this item is not available."
The same message.
badb0yz, can you refresh a link to the manual.
I need some help as swapping ABS module in Passat B5 did not help.
- Please check that you've entered the correct item number
- Listings that have ended 90 or more days ago will not be available for viewing
Anyone tried to repair ABS 5,3 ? Yesterday i've opened one, the electronic part, and the problems seems to be that 2 famous aluminium contacts. I tried to solder them back , but impposible, i need stearinicum acid for solder aluminium with gold. Any tips?
Alusol made by Multicore is the answer for soldering aluminium.![]()
nicolas2015 (20th March, 2015)
OK, but what i need to soder it's very thiny, two aluminium wires to a gold pin, if i use torch all will be damaged. I ataches a few photos with the problem. From what i supose this acid stearinicum works like an activator for soldering.
P.S. -if is not a problem i will post a tutorial from youtube with how repair:https://www.youtube.com/watch?v=UqtowdSDbxU.
hi,
try it.............
nicolas2015 (23rd March, 2015)
You can do it without acid because to much acid damages near gold wires. You have to use less temperature to solder and thin tip.
barho67 (28th March, 2018)
Mr. Mellon has a wright,
rgds,
cuby
