Thread: vu+solo
    Aug 2008
    Post vu+solo
    how do i delete a channel on this image linuxsat-support BH 1.72 UK Ready Backup
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Press forward on dpad and the channel you want to delete highlighted press menu then remove entry.
    You can use dreamset or dbedit to create your own lists.
    Jul 2012
    Good morning to all I ask for help for my vu + clone had only 166 image I discovered later that it was a clone, but now I had purchased I updated the kernel to 3.1.1 then 1.7.6 then also the image but no 1.7 .5 1.7.4 1.7.3 1.7.2 and still nothing does not work now even with the 1.6.6 what should I do? please help thanks
    1 -installing the soloboot.bin with UpdateAllFlash.exe
    2 -installing the UPFLASH120227.bin with renewflash.exe
    3 -Erase the memory with ERASE126.exe
    4 -installing the Secret SOLO-120229.bin with secupd111230.exe
    5 -installing the cfe_solo_2.0 with a usb pen drive
    6 -installing a image XX with the usb pen drive
    but nothing help me please
    DOUGALMCD's Avatar
    May 2011
    Suburbia
    Did you use null modem cable and rs232 board with clone?
    then you do ic update then bootloader cfe 2.0 then image 1.7.5 or below. HTH
    V.I.P. Member benny/9's Avatar
    Nov 2008
    north west uk
    Quote Originally Posted by xxxpitbullxxx View Post
    first have you updated the IC with the small rs232 board
    and a null modem cable, or does the box have a V2 sticker on it?
    to do the update you must use a computer with a fixed 9 pin com port
    this rs232 board wont work with a usb to serial convertor.
    Please Read Carefully!
    No Sky UK NDS Videoguard Hacking Discussions.
    Viewing Pay TV without a valid subscription is illegal
    the files available are kept for experimental & educational purpose only
    original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,
    birmingham
    Default where can i download these files from on this forum
    as my vu+solo has red light i will need do follow this but need the tools and files , it is a clone
