Results 1 to 4 of 4
    May 2011
    Norway
    Default MPPS V12 installation problem help
    I have MPPS V12 adapter and problems with installation!!!
    Install software it's OK,then connect USB it's written :
    This wizard helps you install software for Amt Flash,and then write not found software .
    Please help me!!
    May 2011
    Norway
    Problem solved !!
    Jul 2011
    how did you solve your problem
    May 2012
    italia
    For v12 just instalare the driver manually from device manager, solid path and C-DISC MPPS-DEVICE DRIVER-AmtFlash.inf
    The software does not interface without the atacata
