Results 1 to 2 of 2
    Apr 2013
    Default Streaming on VLC via iDreamX
    I recently bought a Mac and installed iDreamX to stream my DM800HD, previously on Windows I used Dreambox Control Centre. I have a couple of questions which would make things easier for me. I have trouble with VLC. When I stream, I get horizontal lines appearing whenever something moves fast in the video. I had this issue with VLC on Windows too. Another issue I have is VLC cutting the stream off after a couple of seconds. Again, I had the same issue in Windows. However, this cutting off only happens when I stream HD channels. The stream does not cut off on VLC when I stream standard definition channels. On Windows I solved this simply by streaming it in Windows Media Player and everything was fine. This is just a problem with VLC and I've checked online and many people are experiencing it. That is why I'm asking if there is an alternative programme to stream from iDreamX that is compatible on Mac instead of VLC, and does iDreamX support me opening a stream in another programme instead of only VLC.
    If you know of any solution I'd be happy to hear from you.
    Top Poster bugsy's Avatar
    Feb 2009
    Hi mate, never used iDreamX, try using Dreamstrem e2, works perfect for me on windows 8. It is multi platform.
    Downloads
    Cheers,
    bugsy.
