hi all,
I have Skoda Octavia 2010 1.6tdi
03l906023ag CAYC 6930 HW H23
I need dpf off.
what is best tool to read it in SAFE and then write data without issues?
hi all,
I need dpf off.
there is few post here where user says that kess v2 can brick ecu.
I would like to find out what tools are you use to unlock/read/write this ecu.
Kess or galetto can unlock this ecu or need other tool to do it?
I used fgtech V54 clone which worked 3 times out of 5 I've done the last two did not work ECU locked Brick useless no communication line can ecu defunct impossible to recover them, yet software fgtech message ECU unlocked OK. A tip is best to read 95640 and unlock.........
so looks like only kess v2 or galletto can do it.
never no success, fgtech eu, Bricked , on this ecu, interested if kess clone v2 capable or also brick ecu ? if chances are slim, sooner turn away vag 1.6
I have done a number of pcr2.1 ecu's with fgtech eu clone without any issues.
With Kess you can read/write eeprom to make backup. In my case there was one ecu after update in 2014. Galletto couldn't unlock this ecu - after writing mod file car didn't start but there was no problem to write ori file. I recommend to use kess.
VAG
I had clone never had a one problem with it.done many pcr2.1 all worked ok for me.
Now i use ori fgtech but still have clone for s.....
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
soldering the boot wire is very very hard in my opinion as very small, not impossible but i find difficult on the eyes
I need that ecu pinout looks like there is a problem with MAF but I want to check wires first.
getting a fault : maf signal high
swap maf but no different.
I have made hundreds of pcr 2.1 with galletto v53 china and galletto v54 Eu clone.
I have never met an issue.
But if you don't make the connections carefully then you can brick the ecu with any of the clone or original tools.
