Results 1 to 3 of 3
    ecuremap1's Avatar
    Oct 2012
    Default Ford C-MAX EPB Removal
    i have a ford C-MAX that did have a EPB but now has been converted to manual handbrake but the car is still looking for the module but it has been removed
    i have completed a auxiliary vehicle id reset on the abs so the abs knows it doesnt have it anymore
    but the GEM module does still think it has it i know you need to change the as built data but you cant change the orignal config with vcm so maybe i can use orignal abrites??
    so i try to use the file from motorcraft website but the file extension is .ab?? and avdi uses .xml?? i try to change the file extension but still no luck
    can anyone suggest anything?
    many thanks in advance
    ecuremap1's Avatar
    Oct 2012
    anyone? please?
    ecuremap1's Avatar
    Oct 2012
    ? Anyone help?
