Results 1 to 10 of 10
    May 2016
    Post MED 17.5 IMMO OFF
    hello i need immo off for audi a4 1.8 t 2011 med 17.5
    i have both files for original ecu wich is faulty and the replacement ecu , idon't know if by cloning the original ecu car will start or not . anyway i will appreciate your help
    Jul 2016
    ARGENTINA
    Default clonado
    hay esta amigo clonado ECUS CLONADOS.rar
    May 2016
    explain to me please wich file i should copy to ecu ? backup ? eeprom ? flash ? clonado ok ?
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    if you clone by fgtech54, car maybe work. If ist same hardware(ecu?s) read full backup from old and write it to new one(used one)
    May 2016
    i use ktag and hardware is not the same . i tried cloning only eeprom and car doesn't start immo still on but i can see the car VIN on my new ecu .should i try to clone mpc and try ?
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    i think if you have not a same hardware not work... eeprom from old ecu in new ecu with diferent data not work. Must MED17.5 replace with MED17.5 Post numbers of ecu"s
    Oct 2016
    Here try your immo off friend
    audi a4 ecu d'occasion immo free.rar
    Quote Originally Posted by leverage454 View Post
    I just clone your ECU , Copy this eeprom in to the new "audi a4 ecu d'occasion".
    This is the data from your Original ECU:
    VIN: WAUZZZ8KXAN068248
    CS: F3023EFBE2F8C2
    MAC: EB651F7D
    PIN: 34289
    ECU: MED17.5
    Let me know.
    eeprom_new_data.rar
    DUPNICA BULGARIA
    Imoo offf fileee
    Jul 2016
    I think audelino did it already right. Just copy the "CLONADO OK.bin" to your new ecu. He cloned immo data from old to new and i think it could work. Give it a try. Usually you can't copy just all from one to another MEDC17 as there is a OTP area which you only can write once and this contains data for immodecoding.
    @eltiobarbas
    I think this immo data is wrong. It seems to me like a immo5 with 16 byte component security and does not have MAC/PIN.
