Hello everyone, this is my first time trying to read an eeprom. I have an 08 Honda pilot 77960-s9v-A512-C1 when I read using carprog 9.31 it reads all zero`s. After it reads it verifies ok anyone help me out with this. Thanks
Check your connections. How are you reading, with chip removed from board, in an adapter or in circuit?
Reading in circuit, damn chip is so small is hard to solder on to it. I soldered two wires in the back 4 on the chip.
Sent from my SM-G935V using Tapatalk
Yeah I just did one it's a bitch. But you may have wires in wrong place. They should read fine in circuit
How did you do it, any pictures?
ouch,, that looks no good,,
you can try this http://www.ebay.com/itm/TSSOP8-sprin...3D261807833813
or these clips - https://www.amazon.com/Cal-Test-Elec.../dp/B009QBH87M
If i helped you please press thanx
My soldering iron needs new tip. Those look great, if I decide to do this for money will definitely buy them.
Well I tried reading another chip for a Toyota rav4 and got the same reading. I removed the chip from the board and using the A6 connector I get the 00 readings. It looks like maybe my carprog is no good. I used external power and after numerous no chip detected I got a reading of 00.
Make sure pin 1 one your cable is on pin 1 of the chip.
Also make sure your cable is wired correctly. You can find diagrams for the cable on codecard website. I have found some clone cables are wired wrong
http://www.codecard.lt/carprog/adapt...r/prod_54.html
Thanks for the response, I did verify the connector is wired properly and clipped the chip the right way.
Clone or original carprog ? Don't forget to attach the eeprom connector board between carprog unit and a4/a6 connector
Sent from my Moto G (4) using Tapatalk
Clone, I have tried with and without external power and with adapter.
does it read 0000 for all eeproms or just that one ? If for all, than you probably need carprog repair kit
I have tried on two and get 00. Can you point me to the repair kit? Thanks again
http://www.codecard.lt/carprog/carpr.../prod_566.html
