Results 1 to 9 of 9
    Default Which Oscilliscope ??? Coices choices...
    Hi Guys,
    I am thinking of Getting a scope to start trying to learn & improve my diagnostic Firepower.
    I see there are several choices available of course Pico & snap-on are known to be the Best but not knowing too much about them yet thought I would ask the experts.
    1)
    How Nessasary is a scope these days
    2) Are cheaper scopes such as Sealy TA4000/ Hantek / autel worth a look i.e. can they do just a good a job as Pico & snapon scopes if not what are the drawbacks.
    3) What experiences have you all had with scopes good or bad..
    Thought it would be a good discussion to start & maybe if scopes are really as good as I here they are is it worth starting a Forum waveform library????
    Cheers JAPN......
    xoom's Avatar
    Ylakiai
    Rigol DS1054Z. Those are cheap and good But thei are bench scopes I have old DS1052E hacked to DS1102E (100MHz) i use it for cars too )
    Dunker's Avatar
    Yorkshire
    Pico best. Cheap but good for money Autoditex. And I have some of their far cheaper accessories that I use with my Pico. There's alsorts on the market now including some small LCD bench scopes that can be used for auto. I prefer the Pico but they are too expensive. Autoditex do a 4 channel wireless scope as well. Also, the tw@ts at Pico won't let u use their auto software with their better spec scopes anymore. Tossers.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
  4. The Following User Says Thank You to Dunker For This Useful Post:
    japn (18th January, 2018)
    Trstenik - Thun
    If you need to repair cars and If you know how to use it then Hantek USB or similar in that price range is enough .
    If you prefer to repair electronics then non of USB osc. is not good enough.
    Here you can see oscilogram of CAN H-L made by Hantek
  6. The Following User Says Thank You to mikroel For This Useful Post:
    Talking Autoditex oscilliscope
    Quote Originally Posted by Dunker View Post
    Hi there thanks for your reply. I did just look at the Autoditex website, the kits look very well fitted out even including amps clamps for £399 but was interested to know from someone who has used it. The oscilliscope I saw only had 2Mhz Bandwidth and also fairly low sampling rate. What physical effect did this have. Can you still do all the tests quite well with it. I did love the fact it had isolated channels, power supply & good over voltage protection.
  8. #6
    [QUOTE=mikroel;3190960]If you need to repair cars and If you know how to use it then Hantek USB or similar in that price range is enough .
    Loved this reply Mikroel, what model of Hantek are you using? As I was thinking of getting a Sealy Ta4000 as an option which is basically a Hantek 3060. But salesman not recommended it as he says not a good scope. I know the over voltage protection is quite low @ 48v but to me looked a viable option. Even the Hantek 6074be slightly higher spec at 70mhz & 1g/s sampling rate seem good. Waveform library a bonus too.
    is this the 1st Hantek you have owned...
  9. #7
    Dunker's Avatar
    Yorkshire
    I don't have a Ditex but have used one. Resolution could be better I suppose. I have a Techtronics 200mhz 2 channel for work. Bit outdated but i gave 6 or 7 hundred for it and at just short of 3k when new it was a bargain at the time. Now adays I'd probably be going down the Hantek road or something like it for work. I do a bit of hardware reversing so I need something a bit higher spec for home. Just make sure your laptop is fast enough for USB. A true USB3 scope would be the way forward I suppose. Saying that, for £175 on Amazon the Hantek 6074BE looks well worth a gamble for the garage. I might even get one to try for that money.
  10. #8
    Faraday's Avatar
    May 2012
    The dark side of the moon
    I use fluke 97 very good. Stand alone tool in my opinion better.
  11. #9
    Quote Originally Posted by japn View Post
    Hi Guys,
    1)
    Cheers JAPN......
    i have seen a picoscope 3423. Is a 10mhz bandwidth but even a 4425 is only 20mhz. That being said is a 2005 picoscope 3423 still good enough starter for vehicles today. Will it still work with latest Pico software and do can bus or airflow sensors Ect.
