    May 2017
    Default Renault Master 3 alternator and wipers poblem
    Hello can you help me after new alternator change the customer again there is a mistake on the dash with low batery everything is okey there is 14.02v power when working all the fuse is okey the car have problems also with the wipers not stoping do you have any idea i see fuse all is okey is there any reley do you thing is the problem can be the box in motor place can you give me some advais thanks alot
    Jun 2013
    Open motor and clean The ways
    Wysłane z mojego SM-G390F przy użyciu Tapatalka
  3. The Following User Says Thank You to wbart For This Useful Post:
    Mak88 (21st June, 2018)
    May 2017
    i open today and clean everythin but stiil nothing with the wiper is there any reley somewhere or i miss something i have ONE PLUS and one smal wire olso has 12v i thing it must to dont have it do you have any wire diagram for fuses reley for the motor thanks advance
    Aug 2010
    Replace the wiper motor, common problem.
  6. The Following User Says Thank You to ascouser For This Useful Post:
    Mak88 (22nd June, 2018)
    May 2017
    do you thing it can be the wiper motor becouse befor it was working with no stop now it is stop
  8. #6
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    l have a van here the same can you tell me if you fixed it ? l think it might be fusebox under bonnet ? thanks
