Page 7 of 44 FirstFirst ... 2345678910111217 ... LastLast
Results 91 to 105 of 649
Thread: diagun help
  1. #91
    DK Veteran sergej's Avatar
    Latvia,Riga
    "My computer recognizes the SMARTBOX as COM40"
    You see post 74?
  2. #92
    Latvia,Riga
    Emulator wince5 can work " Microsoft Windows 2000 Professional with Service Pack 4 or Windows XP Professional with Service Pack 1" see Windows CE 5.0 Device Emulator - Microsoft Download Center - Download Details
    Emulator wince can work only with com port 1-9.
    If N com port>9 you can delete all hidden com port and
    re-install BlueSoliel-this version BlueSoliel free ,but work
    only with win 2000,XP,Vista.
    Win 98 work with com-port good, win XP bad-need driver
    Giveo.
    You can install Win XP.
    Or setup Diagun software in Mini2440 or PDA with ARM
    processor and wince5.
  3. #93
    Hello sergej, yes I Follow your instructions and managed to connect it on COM6, and I edited 800X480 Extra Eng.cmd to fit COM6. And it worked, it get connected but I couldn't install Givieodriver, maybe beacuse my OS is WIn 7-64bit and the Givieo is for 32 bit I think, What I am doing wrong?
    thanks a lot sergej
  4. #94
    Latvia,Riga
    I buy new processor S3C2440 for my Diagun and when
    I restore it I write.
  5. #95
    Thanks a lot sergej, I see now what is my problem, I will try to install it on a xp, you are adoctor mate thanks a lot
  6. #96
    Latvia,Riga
    I search Giveo for you.
    You connect with smartbox?
    Give picture .
  7. #97
    My DIAGUN died too, worked perfectly for amonth. Then one day I tried to turn it on but does'nt boot up. It shows only the initial logo but nothing else, I found a video on youtube with the exact problem, think is a common failure.
    [ame=http://www.youtube.com/watch?v=ZK1wzL0g0ik&feature=player_embedded]Launch x-431 diagun problem - YouTube[/ame]
    I tried everything, with power connected, without the battery, without the miscro-sd, with the resset button, and it doesn't links with the activesync. Is like someone has erased the Operative system
  8. #98
    Latvia,Riga
    Give picture emulator.
    1.Start emulator from 800X480 Extra Eng.cmd
    2.In open windows emylator left mouse on "Fiash" +
    button PrtSc
    3.Open Paint, Edit-Paste
    4. Save as JPEG
  9. #99
    Quote Originally Posted by sergej View Post
    Give picture .
    I think it did, because the blue led on the smartbox stays still and when I try to connect i get these message
  10. #100
    Latvia,Riga
    See post 72 -see N port.
  11. #101
    Latvia,Riga
    You have problem update smartbox!!!
  12. #102
    Latvia,Riga
    Giveo driver
  13. #103
    Latvia,Riga
    You install new Display in GAG?
    Install Win XP, Giveio.
  14. #104
    Thta message appears when you update your smartbox and whe is firts used. I follow your instructions on post 72 and set the smartbox SPP_SLAVE to port COM6, and edited the 800X480 Extra Eng.cmd to COM6. Then it get connected but showed the message you see on the picture
  15. #105
    Latvia,Riga
    When ready-write.
