Results 1 to 4 of 4
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    Default fiat 500 2019 need help
    car crashed
    fault p1947-68 belt starter generator (bgs)disabled by crash event
    this fault in ecm
    my question
    how to remove this fault
    need any component replaced?
    or need crash remove in ecu?
  2. The Following User Says Thank You to vasko For This Useful Post:
    ZIOMAL4340 (18th April, 2023)
  3. #2
    I also have this fault code today! - car has been repaired after crash, airbag ECU has crash data cleared & no faults just this fault code in ECM - did you manage to clear this or has anybody got some knowledge on this fault code?
    *UPDATE* - If you stumble across this thread, its due to being a 'Mild' Hybrid & uses the 'Alternator' AKA 'Starter generator' - to exit hybrid mode & re-enter combustion engine mode, this gets disabled after a crash & needs resetting with dealer tool only - 5 minute job!
    Jul 2020
    Hello all,
    I have this same problem. Did everyone just request the crash data to be wiped by the dealer?
