Results 1 to 12 of 12
    Junior Member ari998's Avatar
    Oct 2022
    Default Mazda 2 D09H-57K30 SRS airbag
    Hi masters,
    i need help for longitudinal problem from SRS Airbag Module.
    i've try some clear data but its not working.
    there is no DTC for longitudinal problem if i write the original data.
    Jan 2012
    tested solution
  3. The Following 2 Users Say Thank You to wflseba For This Useful Post:
    ari998 (18th January, 2023), fuzz1 (18th January, 2023)
    Oct 2022
    Quote Originally Posted by wflseba View Post
    tested solution
    Hi thanks for support, but DTC longitudinal error still displayed and can't be programmed or calibrated
    Do you have other data change options?
    VVlad's Avatar
    Ukraine Sumy
    This should work.
    Try and report the result
    Pass PM
  6. The Following 2 Users Say Thank You to VVlad For This Useful Post:
    Oct 2022
    Quote Originally Posted by VVlad View Post
    This should work.
    Pass PM
    Dear VVlad,
    thank you for trying to help, but it still displays an error code on the longitudinal sensor from the SRS module.
    is there any other way to solve it?
    thanks..
  8. #6
    Jan 2012
    solution was tested few times probobly ecu is brocken or dump corupted
    Quote Originally Posted by ari998 View Post
  9. #7
    superjet's Avatar
    Aug 2018
    try and report.................
  10. The Following User Says Thank You to superjet For This Useful Post:
    ari998 (19th January, 2023)
  11. #8
    Oct 2022
    Quote Originally Posted by superjet View Post
    Dear superjet
    thank you for trying to help, but it still displays an error code C0062:29 from the SRS module.
    thanks..
  12. #9
    Oct 2022
    forget the previous data. I think there is an error in the HW or the driver, I will have to double check.
    and now, please someone,
    may i ask for help to do a crash reset with this other data,
    thanks before...
  13. #10
    Check ESP/ABS
  14. #11
    Oct 2022
    Dear all,
    case C0062:29 Solved..
    Thank you for the help all...
    Best Regard
  15. #12
    Oct 2022
    Quote Originally Posted by bolonc View Post
    Check ESP/ABS
    nope,
    The problem comes from the internal airbag module
