Results 1 to 9 of 9
    Jan 2023
    Default How to extract EEPROM data from ecu?
    Hi guys, I needs your expertly on how to extract the EEPROM from the ecu
    My car is VW Polo 2017 1.2 TSI
    with Simos 10.22 ECU.
    Can i extract the EEPROM data using OBD2 or need to open the ecu to access the EEPROM chip?
    What tools needed to perform this data extraction ?
    rafal's Avatar
    UK - PL
    data for what ?
    what do you want to do ?
    Jan 2023
    hi, i want to unlock my car speed limit.
    i accidently lock my car speed to 30km/H using OBDeleven
    alexandrosts's Avatar
    Feb 2017
    there where civilization started
    You can read/write this ecu with kess via obd2 port if you want to access and modify maps, but you can set speed limit up and down from the steering wheel what you mena you locked it?
    TO TUNE OR NOT TO TUNE
    Jan 2023
    i accidently changed the "Static maximum speed limit" to 30KM/h using OBDeleven tools.
    rafal's Avatar
    UK - PL
    Quote Originally Posted by kctai View Post
    is NOT possible to increase this value, only decrease it
    you did mess..............
    try reflash ecu by sgo file or change ecu now/ + odis
    Jan 2023
    Quote Originally Posted by rafal View Post
    I thought just get the eeprom dump file and edit the eeprom data will do?
    rafal's Avatar
    UK - PL
    Maybe someone will do for you
    Good luck
    Dec 2022
