Results 1 to 14 of 14
    Sep 2021
    Default BMW E63 645Ci Map Controlled thermostat
    Can anyone help me find or change the map controller thermostat threshold temperature? I think stock temperature is around 114*C and I would like it closer to 90*C.
    Thanks!
    Jan 2023
    Czech Republic
    There is no such map in BMW MEVD17 ecus. Coolant temperature depends on many many factors. Don't worry about it. If you push the car hard enough, it will get closer to your desired 90C on its own.
    Sep 2021
    Hi GPTunes, This is Bosch ME9.2 ECU. The engine is running much too hot for my liking. Oil temp routinely exceeds 120*C which is just absurd.
    I'm more then certain that this car has Map controlled thermostat in which you can alter setpoint of the heater that will allow thermostat to open earlier.
    Jan 2023
    Czech Republic
    Weird I could not line it up with any ME9 BMW mappack/damos I had, what is the sw version?
    Sep 2021
    Quote Originally Posted by GPTunes View Post
    It's 370376
    Sep 2021
    Is anyone able to help? :/
    May 2018
    I was looking for this map very long and ended up with modified thermostat without heater. Then I delete DTC for E-Thermostat and now my car heating up to maximum 94C and got no errors. Another advantage of this modification is confidence, that my car won't go back to higher temps in case of heating element failure.
    May 2017
    Maybe you should help others before beeging for help. Over 1,5 years here but 6 posts of want...
    Its doneable in software but I you dont want or cant help others you maybe need pay someone for.
    Sep 2021
    I can pay you if that's the issue
    I rather not help anyone yet as I'm not so confident about my abilities. I'm currently learning all this stuff and as you probably know it takes a while... I will give back to the forum and it's users as soon as I will be able too. Also, I treated my last post more as a bump, not a demand...
    May 2018
    I still think, that modified thermostat is better option
    Sep 2021
    Hi MikuR1, Could you elaborate?
    May 2018
    I have got modified thermostats, with new bimetal element, calibrated to 88C or 85C or colder if you want. It has deleted heating element and behaves like old good classic thermostats.
  13. #13
    Jul 2021
    I did it few days ago in me9.2.2 n62b48 (flash 2 mega) and with custom thermostat there was a check on dashboard . Not sure in me9.2 check appears but I can find any dtc in this ecu example thermostat cooling coś tam if you want I can help
  14. #14
    Sep 2021
    It would be great if you could
