Results 1 to 10 of 10
Thread: Help DS 150E
    Jan 2023
    Default Help DS 150E
    Здравейте. Нов съм във форума и съм от България. Използвам гугъл преводач и се извинявам, ако не съм бил ясен. Купих клонинг DS 150E със софтуер Autocom 2017 от Китай. В секцията за актуализация адаптерът се разпознава като
    хардуер- CDP+
    сериен номер -100251
    Generic OBD - 114
    Firmware - 1423
    Следващото актуализиране на адаптера не може да се свърже с колата и казва
    хардуер - CDP+
    Generic OBD - 121
    Firmware - 1622
    Нямам Frimware - 1423, ако това е причината. Ще съм безкрайно благодарен на всеки, който може да ми помогне.
    fuzz1's Avatar
    Jul 2019
    Please use only English on the forum
  3. The Following User Says Thank You to fuzz1 For This Useful Post:
    luka1 (4th February, 2023)
    Jan 2023
    Hello. I'm new to the forum and I'm from Bulgaria. I'm using google translate and I apologize if I wasn't clear. I bought a DS 150E clone with Autocom 2017 software from China. In the update section, the adapter is recognized as
    hardware- CDP+
    serial number -100251
    Generic OBD - 114
    Firmware - 1423
    Next adapter update can't connect to car and says
    hardware - CDP+
    Generic OBD - 121
    Firmware - 1622
    I don't have Frimware - 1423 if that's the reason. I will be extremely grateful to anyone who can help me. Sorry for my stupidity with the post. It's my fault.
    Dec 2014
    PL
    Quote Originally Posted by luka1 View Post
    hardware- CDP+
    Generic OBD - 114
    Firmware - 1423
    hardware - CDP+
    Generic OBD - 121
    Firmware - 1622
    Run the software (Autocom which you have installed) Connect VCI to laptop and car. Go to "settings", do a "test", then press the "Update" button. Wait until the update is complete and done.
    If your VCI is dual board then you can use FW max up to 1622. It can also be 1423 as well as 1430.
    FW 3201 or 3200 is for VCI with single PCB.
  6. The Following 3 Users Say Thank You to Mario6 For This Useful Post:
    fuzz1 (10th February, 2023)
    Jan 2023
    Mario6,Thanks for the reply. The actions I perform - I start Delphi 2017 on the laptop. I connect the reader to the laptop and the OBD on the car. Settings - hardware settings - VCI connection Search/Com-port/. It detects COM4. The section below says
    хардуер - CDP+
    Generic OBD - 114
    Firmware - 1423
    Then I press the "Update" button and wait for the update to finish. The lights on the tester blink. I finish with "OK". The left section says
    hardware - CDP+
    Generic OBD - 121
    Firmware - 1622
    I look for the "Test" button and everything is OK. I select the car on which the reader is turned on and press the "ISS" button. I put the ignition key of the car in the "Contact" mode and the engine does not work. The relays of the reader crackle, but there is no communication with the car. I have done it several times on different cars and the result is the same. I have changed the USB and OBD cables. The reader has two boards.Please help if there is someone with a similar problem.
  8. #6
    Dec 2014
    PL
    If you are doing the FW update correctly, the next time you run "TEST" it should be FW 1622 not 1423.
    Watch a movie. If you do as in the video and nothing changes, your VCI may be damaged. It's best to buy a good VCI with a single A++ PCB and start using Autocom/Delphi 2020.23.
    https://www.youtube.com/watch?v=tHyxaunjsec
  9. The Following 2 Users Say Thank You to Mario6 For This Useful Post:
  10. #7
    Jan 2023
    Mario6,I have described all your instructions in a post above. I have watched enough video clips. I read a lot on the forums. Still, we are not stupid in Bulgaria. I do all the steps correctly. Now I am looking for someone with a similar problem. Every time I turn on the reader, it shows Frimware 1423, and after update Frimware 1622. After disconnecting from OBD and connecting again to OBD, it shows Frimware 1423. It does not save update 1622. With WOW 5.00.8 it works perfectly, which makes me think that the reader works. I am using a dual-board reader and I am looking for help for a dual-board reader. I know what is good and it is Delphi. A single-board or dual-board Chinese reader is Chinese. Please help on the subject. I want to try to build a
    Generic OBD - 114Firmware - 1423
    Unfortunately, I do not have Firmware - 1423. Here on the site there is a collection of Autokom firmware in the form of RAR, but despite "thanks" and "comment" it does not allow me to download it. I will always be grateful to anyone who responds with useful advice .
  11. #8
    Dec 2014
    PL
    Ok now I understand.
    If you can't download RAR with FW 1423, do this:
    In SW 2017.3, rename "Firmware" to "Firmware 1622". Go to root folder "WOW" - "ac_diagnosis_module"----"firmware") copy "firmware" and paste to SW 2017.3 root folder.
    It should work.
    However, I think you should try AC/Del 2020.23. It's much better. Also works with dual PCB VCI and FW 1423.
    I also encountered a situation where the 2017.1 software was prepared for the VCI version with the serial number 30251 and then there was no connection with the car. (VCI 100251)
  12. The Following 2 Users Say Thank You to Mario6 For This Useful Post:
    fuzz1 (10th February, 2023), luka1 (10th February, 2023)
  13. #9
    Jan 2023
    Mario6,THANKS.After I bought a non-working two-board reader, I bought a single-board Chinese one.I currently have Autocom 2020.23 installed, and the one-board reader works fine, but the two-board one doesn't. During the time, I didn't give up on restoring the two-board reader. I started various attempts. I replaced different fimware from Autokom ,Delphi,Opus,Eclipse,WOW.There was always something a little missing.I came to the conviction that I need the right fimware.Example.I put WOW 5.00.8 fimware in Autocom 2017.3 fimware and WOW works but Autocom doesn't.After your kind help it remains to I continue the attempts to revive the two-board Chinese. I downloaded fimware 1423 RAR which I did not have. At the moment in Bulgaria it is -11 degrees and it is too cold for me to continue the experiments outside. I do not work professionally with car diagnostics. I do everything for me and friends. One more once again I say thank you for your help. Be healthy.
  14. The Following 2 Users Say Thank You to luka1 For This Useful Post:
    fuzz1 (10th February, 2023), Mario6 (10th February, 2023)
  15. #10
    May 2019
    Default cdp+ 2020.23
    Please send me 1423 wirmvare,thank you
