Page 1 of 4 1234 LastLast
Results 1 to 15 of 59
Thread: Dacia KEY codes
    matik185's Avatar
    Jun 2018
    Europe - PL
    Default Dacia KEY codes
    Hello
    Can someone try to decode for me key code for Dacia ??
    Key code : 000700
    Xhorse Dolphin XP005L , INSTACODE - no results...
    Dec 2010
    Nottingham
    dacia key codes are normally direct cuts , where did this code come from ?
  3. The Following 2 Users Say Thank You to rapidlocksmiths For This Useful Post:
    matik185 (2nd February, 2023)
    matik185's Avatar
    Jun 2018
    Europe - PL
    Verified supplier But not always.. lasy time had same situation.
    matik185's Avatar
    Jun 2018
    Europe - PL
    Quote Originally Posted by rapidlocksmiths View Post
    You help me last time with decoding Dacia KEY cut with ninja laser remember ?
    Can you try to check that code too ? Many thanks
    hi
    Dacia KEY code - 33132223
  7. The Following 3 Users Say Thank You to key4man For This Useful Post:
    matik185 (2nd February, 2023), p1et (4th February, 2023)
  8. #6
    matik185's Avatar
    Jun 2018
    Europe - PL
    Quote Originally Posted by key4man View Post
    hi
    Will check IT
  9. #7
    vialli's Avatar
    Aug 2018
    Romania
    For VAC102 with 6 cuts I got this: 211243
  10. The Following User Says Thank You to vialli For This Useful Post:
  11. #8
    Dec 2010
    Nottingham
    It all depends what make model and year and key blank
    ninja laser states that for dacia if the HU179 key on ic card 1891 , the code 000700 relates to key cuts of 33132223 as key4man has already correctly stated
    but if vac102 6 cut lock then 0700 could be the code which would be 211243 as vialli has correctly stated
    in future to avoid confusion you must state make model and year and you will get more accurate answers relating to the key series and blank you require , full information will always help get the accurate answer
  12. The Following 4 Users Say Thank You to rapidlocksmiths For This Useful Post:
    key4man (3rd February, 2023), matik185 (2nd February, 2023), Supas (2nd February, 2023), vialli (2nd February, 2023)
  13. #9
    matik185's Avatar
    Jun 2018
    Europe - PL
    Sorry for that and many thanks for info
    Its Dacia Logan 2015 year
  14. #10
    Dec 2010
    Nottingham
    on that year of dacia logan it should be either VA2 blade or HU179 blade , so by the code you was given it will be the new hu179 blade and the cuts Key4man gave you of 33132223
  15. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
  16. #11
    matik185's Avatar
    Jun 2018
    Europe - PL
    I will check and confirm here Thabks for now !
  17. #12
    matik185's Avatar
    Jun 2018
    Europe - PL
    HU179 worked like charm with that bites
    Many many thanks
  18. The Following User Says Thank You to matik185 For This Useful Post:
    rapidlocksmiths (4th February, 2023)
  19. #13
    Dec 2010
    Nottingham
    thanks for concluding thread with the outcome
  20. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    matik185 (4th February, 2023)
  21. #14
    Apr 2019
    Is it any other tool or software that could handle this Dacia codes besides Keyline?
    Tried to order a key cut to Dacia code from 3dG but even they faild.
  22. #15
    Dec 2010
    Nottingham
    its a pretty safe bet that if keyline machines have the codes then silca modern machines will have them too as factories next door to each other and copy each other .
    not on instacode at present and not on the china machines , not sure what machines 3d have now when they cut keys to code , obviously not keyline and most likely what they sell
    if silca futura has it then the silca key program would have it too .
  23. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    rokibar (11th February, 2023)
