Page 1 of 7 123456 ... LastLast
Results 1 to 15 of 102
    Feb 2023
    Default I make some EDC15P multimap
    Upload file what you need
    KD-SG Part number ecu preffered!
  2. The Following 9 Users Say Thank You to sharktune For This Useful Post:
    ChriGra07 (19th February, 2023), goldkamel (22nd April, 2023), Gufa378 (16th June, 2024), jamienatorr (29th April, 2023), valdejuelas (19th February, 2023), valygolf (12th February, 2023), volkswagen1234 (6th February, 2023), ZeXsY (14th February, 2023)
  3. #2
    S0nda's Avatar
    Nov 2021
    Reading....
    Quote Originally Posted by sharktune View Post
    let's see this how you will do? edc15p+ vag
    Autotuner Master - FLEX Master - DFOX Master (DFBtechnology) PCMflash 1.3.8 - VCDS hex v2 - Scanmatik 2 pro - Launch - Odis
    "clones" -> Ktag - Kess v2 - Mpps v22 - FGtech - Inpa -
    WinOLS 5
    IF helped! Press "Rep & Thanks"!
    Feb 2023
    Pass in PM
  5. The Following 2 Users Say Thank You to sharktune For This Useful Post:
    gege974 (10th January, 2025), S0nda (6th February, 2023)
  6. #4
    S0nda's Avatar
    Nov 2021
    Reading....
    Pass in PM
    will test and let u know
    WinOLS 5
  7. The Following User Says Thank You to S0nda For This Useful Post:
    Ecumotor (3rd August, 2023)
  8. #5
    Mar 2017
    Portugal
    here pls
    Golf4 ASZ.rar
  9. #6
    Jan 2019
    Default Mulimap
    hi please do multi map on the below
    ECU type EDC15P+
    Part number 0281015432
    Software ID 038906019PJ SG2631
  10. #7
    Feb 2023
    Pass in PM sent
  11. The Following User Says Thank You to sharktune For This Useful Post:
    marko6jpt (6th February, 2023)
  12. #8
    Feb 2023
    Quote Originally Posted by supremeza View Post
    ECU type EDC15P+
    Done. Pass in pm.
  13. #9
    Jan 2013
    POLAND
    This is file My ASZ
    A3 ASZ 130HP 038906019FT 366273
    Please create multimap
    Regards !
  14. #10
    fudballer's Avatar
    Aug 2019
    Serbia
    Hey, can you do for me on Audi A4 B6 EDC15 96kw. Thank you very much
  15. #11
    can u do for me please .
    vw polo 038906019PJ 394165
  16. #12
    alonedark's Avatar
    Feb 2017
    ecuconnection manual multimap edc15
    Bosch EDC15 MapSwitch
    So for years tuners have tried various different techniques to have multiple tunes in one ECU. There are several advantages to this:
    1. Multiple tunes with different output power levels
    2. One tune can be tuned so that engine won’t start: sort of like an added level of security as the driver needs to switch into the tune which will start the engine
    3. Different fuels need different ignition parameters such as ignition timing and duration to name a couple.
    The present method to achieve this was with methods that involved opening the ECU and changing the hardware(flash memory with double the size to have 2 tunes as an example). In this post I am going to write about my journey to achieve a software based solution on the Bosch EDC15 ECUs.
    Here is a video of it in action:
    The basic idea is to have the ECU switch between the different datablocks(this is unique to the EDC15, they have 3 datablocks for different variants such as Automatic, manual and 4×4). The condition to switch between datablocks could be as simple as a brake pedal and cruise control button being pressed simultaneously. The selected map can be visualized using the available outputs, such as:
    1. Glow lamp
    2. Engine malfunction lamp
    3. Cruise control lamp
    4. RPM indication in cluster
    I chose the last one as I found it to be a clear indicator(1000rpm for 1st datablock, 2000 for 2nd, etc) whereas if I were to use any of the lamps, I would have to count the number of blinks(2 blinks for 2nd datablock, 3 for 3rd, etc)
    Now for the boring details on the magic trick:
    1st step is to find how the CANBUS is handled. There is a buffer in RAM in which the messages are stored before they are transmitted.
    On edc15, finding the buffer is easy. Example: Search for sequence of bytes: 0x280 or 0x288 or any other CAN id used by the ecu. This will point you to the code which handles comms:
    ROM:00094156 mov r5, #280h
    ROM:0009415A mov CAN_280, r5 ;CAN_280- RAM buffer handling id -0x280
    ROM:0009415E movb rl4, #8
    ROM:00094160 movb byte_C743, rl4
    ROM:00094164 mov r4, #288h
    ROM:00094168 mov CAN_288, r4
    ROM:0009416C movb rl4, #8
    ROM:0009416E movb byte_C74F, rl4
    ROM:00094172 mov r4, #380h
    ROM:00094176 mov CAN_380, r4
    ROM:0009417A movb rl4, #8
    ROM:0009417C movb byte_C75B, rl4
    ROM:00094180 mov r4, #480hNow that you’ve found the CAN buffer, I referred to the CAN section in the publicly available Bosch documents for this ECU. Below, Ive shown the CANBUS buffer handling ID 0x280 in my ECU.
    MEM_EXT:0000C744 CAN_280: ds 2 ; DATA XREF: ROM:0009415Aw
    MEM_EXT:0000C746 byte_C746: ds 1 ; DATA XREF: ROM:000945DCw
    MEM_EXT:0000C746 ; ROM:0009463Ew ...
    MEM_EXT:0000C747 byte_C747: ds 1 ; DATA XREF: ROM:0009468Aw
    MEM_EXT:0000C747 ; ROM:0009475Ew
    MEM_EXT:0000C748 can_nmot_low: ds 1 ; DATA XREF: ROM:0009468Ew
    MEM_EXT:0000C748 ; ROM:00094788w
    MEM_EXT:0000C749 can_nmot_high: ds 1 ; DATA XREF: ROM:00094692w
    MEM_EXT:0000C749 ; ROM:00094790w
    MEM_EXT:0000C74A byte_C74A: ds 1 ; DATA XREF: ROM:00094696w
    MEM_EXT:0000C74A ; ROM:00094814w ...
    MEM_EXT:0000C74B byte_C74B: ds 1 ; DATA XREF: ROM:loc_948A0w
    MEM_EXT:0000C74B ; ROM:000948CAw
    MEM_EXT:0000C74C byte_C74C: ds 1 ; DATA XREF: ROM:00094D2Ew
    MEM_EXT:0000C74C ; ROM:loc_94DB6w
    MEM_EXT:0000C74D byte_C74D: ds 1 ; DATA XREF: ROM:0009469Ew
    MEM_EXT:0000C74D ; ROM:000947E6w
    MEM_EXT:0000C74E byte_C74E: ds 1 ; DATA XREF: ROM:000945C0w
    MEM_EXT:0000C74F byte_C74F: ds 1 ; DATA XREF: ROM:0009416Ew
    To use the rpm gauge for showing the present map(or any other parameter like boost, SOI,etc), you’ll have to modify the subroutine writing to bytes 3 and 4 of the CAN id 0x280
    ROM:00094780 calls 9, sub_94002
    ROM:00094784 add r0, #4
    ROM:00094786 mov r9, r4
    ROM:00094788 movb can_nmot_low, rl4
    ROM:0009478C mov r4, r9
    ROM:0009478E ashr r4, #8
    ROM:00094790 movb can_nmot_high, rl4
    ROM:00094794 mov r1, word_C420
    ROM:00094798 add r1, word_C426
    ROM:0009479C cmp r1, word_F962
    ROM:000947A0 jmpr cc_SGE, loc_947A6
    ROM:000947A2 mov r9, r1
    ROM:000947A4 jmpr cc_UC, loc_947AA
    r4 contains the actual RPM. We will modify this value to whatever we want; to show the map selected in our case.
    I inserted my call at 94784, to my routine. Its upto you to decide where to insert this call, but make sure you don’t change the original logic.
    Next step is to take inputs like clutch, brake or cruise control.
    This can also be inferenced from the CAN buffer.
    example: id 0x280, byte 0, bit 4 is B_kuppl(clutch pedal).
    Find the code which writes to this bit, and you will find B_kuppl
    ROM:00094EBC movb rl4, word_C49A+1
    ROM:00094EC0 jmpr cc_NZ, loc_94ED0
    ROM:00094EC2 mov r4, word_14D6
    ROM:00094EC6 movb rl5, [r4]
    ROM:00094EC8 jmpr cc_NZ, loc_94ED0
    ROM:00094ECA movb rl4, #8
    ROM:00094ECC orb byte_C746, rl4
    As seen in above code, 0xC94B contains the status of the clutch pedal. But this is not the global variable. I suppose, this is a temporary RAM address to which the clutch switch status is copied when this subroutine starts(so that as long as the subroutine is still being executed, any change in the clutch status will not be updated. Otherwise, it’s possible that at the start of the subroutine the status of the clutch is different from that when the subroutine ends, resulting in unpredictable behavior)
    Finding the global variable by searching for xrefs to 0xC94
    ROM:0009433E movb rl2, byte_C370
    ROM:00094342 movb word_C49B, rl2
    0xC370 is the global variable for B_kuppl.
    Repeat this for other variables you want to use(cruise control status is on id 0x388/0x38A and brake pedals on 0x288)
    Now, for mapswitching on EDC15, you need to change the DPP’s
    Each datablock is referred using DPP0, DPP1 and DPP2. DPP3 is used for CAN.
    datablock 1:
    DPP0- 0x34
    DPP1- 0x35
    DPP2- 0x36
    datablock 2:
    DPP0- 0x38
    DPP1- 0x39
    DPP2- 0x3A
    datablock 3:
    DPP0- 0x3C
    DPP1- 0x3D
    DPP2- 0x3E
    This is the code I wrote for switching between maps and displaying boost on RPM gauge.
    $MOD167 ; Define C167 mode
    $SEGMENTED ; Segemented memory mode
    $CASE ; Symbols case sensitive
    $include (reg167.inc)
    NAME MINIMON
    ASSUME DPP3:system
    StackData0 SECTION DATA SYSSTACK ; Data Section to reserve
    ; Stack-Memory
    DSB 20H ; 32 Byte
    StackData0 ENDS ; End of Dummy-Section
    DriverCode0 SECTION CODE PUBLIC 'CDRIVER'
    DriverProc PROC FAR
    mov r4, 0xc036 ;boost
    shl r4,#2
    movb rl1,0xc370 ;b_kuppl
    jnb r1.0, needle
    movb rl1,0xc379 ;cc_cancel toggle button
    jnb r1.0, xyz
    movb rl1,#1
    movb 0xc76e,rl1 ;cc_off debounce
    jmpr cc_uc, needle
    xyz:
    movb rl1,0xc76e
    jmpr cc_z, needle
    movb rl1,#0
    movb 0xc76e,rl1
    movb rl1,0xc76f ;delay counter
    jmpr cc_nz, dpp
    movb rl1,#0x7f ; initialize delay counter so that r4 isnt updated by the ECU for atleast ~ 40ms * 0x7F= 5080ms ~ 5sec
    movb 0xc76f,rl1
    jmpr cc_uc, needle
    dpp:
    cmp dpp0,#0x3c
    jmpr cc_eq, dppl
    mov dpp0,#0x3c
    mov dpp1,#0x3d
    mov dpp2,#0x3e
    jmpr cc_uc,needle
    dppl:
    mov dpp0,#0x34
    mov dpp1,#0x35
    mov dpp2,#0x36
    needle:
    mov rl1,0xc76f
    jmpr cc_z,end1
    subb rl1,#1
    mov 0xc76f,rl1
    cmp dpp0,#0x3c
    jmpr cc_ne, n1
    mov r4,#0x2ee0
    jmpr cc_uc, end1
    n1:
    mov r4,#0x3e80
    end1:
    add r0,#4
    mov r9,r4
    rets
    DriverProc ENDP
    DriverCode0 ENDS
    END
    I suggest writing your own code, as mine can be a bit difficult to follow
    Basically, my code does this:
    – check if clutch is pressed, if yes then continue.
    – check if cruice control cancel button is pressed. If yes, store 1 in a free ram byte ( lots of free ram in this ECU, 0xC820-0xC82F is free on all the edc15’s I’ve worked on, enough for our small subroutine) and exit the subroutine
    This is done to “debounce” the button press (as long as the button is pressed, no change will take place)
    – check if the “debounce” ram byte is 1, if yes, set it to 0 and switch maps( by changing the DPP’s)
    – To display the map selected understand how the rpm is displayed on the instrument cluster.
    Lets say you want the rpm needle to show 2000rpm. There is a factor of 4.
    So the transmitted CAN message for rpm is 2000*4= 8000 which corresponds to 0x1F40 in hex
    All we need to do is replace the value in r4 with the value you want to display.
    – Setup a counter for displaying the selected map. This is necessary because replacing r4 with the desired value once is not enough. The main loop takes around 40ms to execute. So after 40ms r4 will get overwritten by RPM and the needle will not show the value you wanted it to show. Look at my code for a better understanding…
    Compile using Uvision or a compiler of your choice. Load the output hex file into a hexeditor, search where your code begins, and copy it to a free space in your flash. Then insert a call to your new function. I chose to insert my call at 0x94784(0x14784 in Hexeditor) Free space in my file – 0x1A000 which translates to 0x9A000
    Hence, opcode for call: DA 09 00 A0
  17. The Following 5 Users Say Thank You to alonedark For This Useful Post:
    Derikdvs (18th January, 2025), goldkamel (25th July, 2023), Meat-Head (7th December, 2024), SALAS (19th February, 2023), ZeXsY (14th February, 2023)
  18. #13
    alonedark's Avatar
    Feb 2017
  19. #14
    Feb 2023
    Ok and?
  20. #15
    alonedark's Avatar
    Feb 2017
    is only a information im sorry for you
