Renault Sandero 2020 Add key PCF7939 ( 4A ) 100% ok
Upa-S ,Vvdi key tool, Zedfull, Xpad, KM100, Obdmap, Scanmatik pro2, Ioterminal, Pcmflash, Mdflasher, Fvdi, Ck100, Fvdi, Roudrill
Renaualt Master 3 2015, read password (connect wifi internet, calculating online), add key ok and remote control work.
fuzz1 (22nd August, 2023)
Has anyone used the KM 100 to add a key to a Honda Fit year 2013? GE-6
Key 313MHz
It's keyless but you have to turn ignition to start it. It's not keyless. I have tried to add a key both start stop and bladed but can't get it to work.
Can someone please help?
I used the KM 100 on newer Honda Fit and worked fine.
I tried on Mitsubishi Eclipse Cross year 2021
Strange issue
The car opens with remote starts and runs fine. However i noticed that every now and then it says key not present even when the car starts. I need to bring the remote to the button to get rid of the message.
The original key from Mitsubishi no such issues.
Used the same autel keys on a Honda jazz/fit no issues
Nissan qashqai 2009, AKL succesfully with km100... unlocked eslc, learned the blade key, then program smart key part.
Renault clio 2002, learn new key succesfully...
Opel astra G 2004, AKL... read ecu (edc15c7) eeprom (with vvdi prog)to find pin, then program the key with km100 succesfully.
fuzz1 (22nd May, 2024)
It has issues with older Honda systems, id13 and some early id46... after turning ignition on for the second time it hang "communication time-out". I just use other tools for those cars, otherwise a nice handheld.
Ford transit 2008, akl, succesfully...
2018 Nissan Livina key blade failed.
Could not make it work for akl Kia Sportage 2019. Read pin but could not program key. Was done in 5 minutes by some other programmer.
Succesfull adding key>>> Logan2, 2016 4A chip, Laguna2,3, Megane2,3, Clio 3 key, skoda octavia 2 2015, Toyota Yaris 2013
Raould (23rd May, 2024)
Does it work well with the old keys? Even those not listed in the KM 100?
I have a strange issue using the autel universal keys on mitsubishi eclipse cross 2021. Programs fine works ok. Just keeps getting message key not found on dash. But car starts and runs. Original key does not cause that issue. Program two autel keys same issue on this mitsubishi. You have to bring the key to the on of switch to get rid of the message. The keys were programmed to other Honda's worked without issues
this device will not do either of the cars you mention , its a chinese tool with an innacurate chinese coverage list , maybe take it up with the toolmaker or your supplier .
