Page 1 of 3 123 LastLast
Results 1 to 15 of 31
    Apr 2022
    Default Kia K2500 Dash 93S56 Mileage Correction
    Hi guys tell me please? Iv tried correct kia k2500 dash with 93s56 chip
    Now I tried with digiprog all goes ok until I put back in car then it works for awhile then gages stop work then mileage display error
    So I'm not sure if digiprog corrupted the file.but I do have the original backup with digiprog..
    Please can you check both files or calculate my digiprog original back file?
    Original mileage was 271105km
    Need it 87105km
    Please
    Sent from my SM-A226B using Tapatalk
    Apr 2022
    here files original and digiprog moded file
    Apr 2022
    Here pic of dash after digiprog mileage correction
    epd1221's Avatar
    Nov 2011
    usa
    both of your files are the same but here is modified file 87k
  5. The Following User Says Thank You to epd1221 For This Useful Post:
    Nazo (9th February, 2023)
    Apr 2022
    Quote Originally Posted by epd1221 View Post
    Thanks epd1221 I will write your file with vvdiprog this time
    Thanks much appreciated
    Apr 2022
    Bro if both files are same then what did digiprog do before when I fitted the dash in car the dash showed the mileage digiprog made for an hour than it displayed error afterwards
    But thanks for the file I will keep you updated tommrw after I fit the cluster
    Apr 2022
    Bro put your file but now no mileage display * no garges work
    So I'm not sure now so I will put original file and try
    Apr 2022
    Please is it possible to read the 93s56 without removing it?
    Look pic of pcboard & chip
  10. #9
    Apr 2022
    Here is pic of pcboard is there way to read 93s56 chip without removing it?
  11. #10
    budata's Avatar
    Feb 2018
    Bulgaria
    Hello, I don't know what programmer you use, but 5 seconds of work and eeprom crashed....what's bothering you..?
  12. #11
    lucic66's Avatar
    Aug 2015
    Try this dump in circuit,use one bridge to cristal...
    Quote Originally Posted by Nazo View Post
  13. #12
    Apr 2022
    Quote Originally Posted by lucic66 View Post
    Ok I will try your file
  14. #13
    Apr 2022
    Quote Originally Posted by budata View Post
    Hi budata I'm using vvdiprog to write its good eprom programmer.
  15. #14
    epd1221's Avatar
    Nov 2011
    usa
    remove eeprom its safer process and put file should work no problem my file and lucic66 file are the same
  16. The Following User Says Thank You to epd1221 For This Useful Post:
    Nazo (10th February, 2023)
  17. #15
    Apr 2022
    Yes I remove it will try again..
    Tell me please does anyone have pinout to power this cluster on bench to check the mileage display?..because the car is far please
