Page 21 of 33 FirstFirst ... 11161718192021222324252631 ... LastLast
Results 301 to 315 of 490
  1. #301
    Feb 2014
    But still have much higher coverage than AVDI's new programmer for a fraction of the price... Sad, I really like AVDI and was hoping they would at least provide full coverage.
  2. #302
    Mar 2018
    UK
    How long usually need to activate MQB function after payment?
  3. #303
    Aug 2015
    BEHIND YOU
    Quote Originally Posted by Manta1600 View Post
    same day ... if you are interest text me
    IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
  4. The Following User Says Thank You to eliaselias For This Useful Post:
    Manta1600 (2nd June, 2023)
  5. #304
    Jun 2015
    United Kingdom
    vvdishop can get it activated within 24 hours.
  6. #305
    Quote Originally Posted by sniegavirs View Post
    Is the donor dash the same HW?
    ok not got this done yet.so my original dash does not power on .my fault because i shorted track when i resoldered it and powered it up i think.i have swapped immo data to another dash and this does still power up.so can sync data still be calculated.as i dont think vvdi prog writes the whole flash. or can sync data be calculated from the donar dash then adapted to ecu. thanks
  7. #306
    Mar 2018
    UK
    How to check is it activated
    I ordered from xhorseshop. co. uk and no comunication with them
  8. #307
    Maartinj's Avatar
    Nov 2010
    open VVDi Prog and read cluster to see in LOG on the bottom , or simple talk with seller to confirm
  9. #308
    Mar 2018
    UK
    Quote Originally Posted by Maartinj View Post
    Is it tru that at the moment the 3rd party calculation not working?
  10. The Following User Says Thank You to Manta1600 For This Useful Post:
    musti418 (13th June, 2023)
  11. #309
    Maartinj's Avatar
    Nov 2010
    working good
  12. The Following User Says Thank You to Maartinj For This Useful Post:
    Manta1600 (13th June, 2023)
  13. #310
    honingkoning's Avatar
    Dessert
    Guys is this option Ok for Odo correction.
    Is there a module in vvdi2 to precode/program mqb key for akl situation??
    Wbr
  14. #311
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by honingkoning View Post
    Wbr
    all can be do from vvdi2
    only need get synch data after you provide LOG to 3rd part service
    once you contact this guy he will explain you how / what to read
  15. #312
    Dessert
    Synch data also needed for Odo?
    Or just for the Immo part.
  16. #313
    Feb 2014
    Just for IMMO of course. Sync data is for dealer key generation.
  17. #314
    Dessert
    Quote Originally Posted by autoTkey View Post
    In that case this option is cheap
    I was thinking maybe all data is in a way crypted and always need to buy it encrypted also for Odo purposes.
  18. #315
    Feb 2014
    Well yes, the whole dump is crypted and the processors are locked. But for ODO you don't need sync data. The servers of VVDI/AVDI and the other tools decrypt the dash/immo data but they cannot get the sync data which is only stored in the working key. So currently you have one option to get the SYNC data (when key is missing) - use paid service to get it from VAG server. Soon there may be a second option - to generate the SYNC yourself by reading all the computer modules in the car (ECU, DASH, ELV, Transmission...) but for the moment there's no tool which can read the ELV if fitted.
  19. The Following User Says Thank You to autoTkey For This Useful Post:
    tepSIJA (15th June, 2023)
