Results 1 to 9 of 9
    Jan 2020
    romania
    Default audi a3 8p dash coding
    hello, i have a problem with instruments on an audi a3 8p, 8p0 920 981a, win: wauzzz8p65a093947, i cannot code the module as vcds said, -without washer fluid sensor, with seatbelt warning, country germany, manual transmision, every combination that i tried something does not work(eg. 0001004 buttons for bc not working), can someone help me with the correct codin, thanks
    nil's Avatar
    Polska
    Hello
    Try to use the login/security access procedure with the code: 13861 and only after accepting by the driver perform the coding instruments modul.
    Jan 2020
    romania
    the problem is that the controller Accept the code, every code that i used, but if i code after vcds help info, for example 0001005, or 0011064, or 0411111 or 0000001 etc, every combination that i tried someting is not working well, in some examples buttons for bc does not work, cannot change/select in the menu. the problem is that the car is not having sensor for washing fluid and on cluster appears washer low.
    Nov 2016
    What original coding do you have?
    If I helped you, click on reputation and thanks.
    If you don't thank for help and give a reputation, you won't get help from me again.
    You use my help at your own risk.
    Jan 2020
    romania
    0004104 this is the code when i took the car ,dont know if original or not
    nil's Avatar
    Polska
    Coding in the counter will not turn off the low washer fluid level indicator (no such option). Try to connect pin 20 (if I remember correctly) in the meter through a resistor with the ground of the vehicle.
    Coding A3 8P Instrument Cluster
    Coding
    • ????xxx: Equipment
      • +0001 = 2nd Fuel Tank Characteristic (All-Wheel Drive)
      • +0002 = Highline without DIS (for Midline variant 9Q3 - Automatic without DIS)
      • +0004 = Manual Transmission (not midline variant 9Q3)
      • +0008 = 2nd tire circumference pair (e.g. winter tires)
      • +0016 = Tire Pressure Monitoring (MY 2007+)
      • +0032 = Advanced Front Lighting System (AFS / MY 2006+)
    • xxxx?xx: Country
      • 0 = Germany
      • 1 = Rest of World (RoW - Left Hand Steering)
      • 2 = USA
      • 3 = Canada
      • 4 = Great Britain (Right Hand Steering)
      • 5 = Japan (Left Hand Steering)
      • 6 = Arabien States
      • 7 = Australia
      • 8 = Rest of World (RoW - Right Hand Steering)
      • 9 = Japan (Right Hand Steering)
    • xxxxx?x: Seat Belt Warning
      • 0 = No Seat Belt Warning
      • 1 = Europe-NCAP (permanent visual warning and acoustic warning active for 91 seconds)
      • 2 = USA and Canada OLD (visual and acoustic warning for 6 seconds)
      • 3 = USA and Canada NAR-NEW (permanent visual warning and acoustic warning active every 30 seconds)
      • 4 = Europe-NCAP (including passenger - permanent visual warning and acoustic warning active for 91 seconds)
      • 5 = USA and Canada OLD (including passenger - visual and acoustic warning for 6 seconds)
      • 6 = USA and Canada NAR-NEW (including passenger - permanent visual warning and acoustic warning active every 30 seconds)
    • xxxxxx?: Illumination
    nil's Avatar
    Polska
    Definitely pin 20 in a 32 pin connector
  8. The Following User Says Thank You to nil For This Useful Post:
    dragos1294 (2nd March, 2023)
    Nov 2016
    Have you tried 0000104?
  10. #9
    Jan 2020
    romania
    yes i tried 0000104, but bc buttons not work
    i put a resistor bewteen pin 19 and 20, turn off, thanks, strange thing is vcds actualy hava a code for washer fluid off but does not work
