Results 1 to 2 of 2
    prevozsa's Avatar
    Mar 2015
    Bosnia
    Default Need pinout octavia 2 dash
    Need pinout for cluster octavia 2 tnx
    Oct 2016
    Slovakia
    36-pin connector T36a:
    1 - Terminal 15 - Input
    2 - Terminal 30 - Input
    3 - not assigned
    4 - not assigned
    5 - Brake fluid level warning contact
    6 - Handbrake warning switch
    7 - Immobilizer reading coil
    8 - Immobilizer reading coil
    9 - not assigned
    10 - not assigned
    11 - not assigned
    12 - CAN L, dash panel insert
    13 - CAN H, dash panel insert
    14 - not assigned
    15 - wake up (wake up wire) - Input
    16 - Fuel level sender -2- (only for vehicles with four-wheel drive)
    17 - Fuel gauge sender
    18 - Fuel gauge sender
    19 - Terminal 31 - Input
    20 - not assigned
    21 - not assigned
    22 - Brake lining/pad wear sender, front left
    23 - not assigned
    24 - not assigned
    25 - Oil pressure switch
    26 - Oil level/oil temperature sender
    27 - not assigned
    28 - Speed signal - Ouput
    29 - not assigned
    30 - not assigned
    31 - not assigned
    32 - not assigned
    33 - Terminal 31 for sender - Output
    34 - Windscreen washer fluid level sender
    35 - Coolant shortage indicator sender
    36 - Ambient temperature sensor
  3. The Following User Says Thank You to jokir For This Useful Post:
    prevozsa (6th March, 2023)
