    Jul 2018
    Default Skoda Fabia mk1 Instrument cluster / Immo
    has anyone had any luck reading the SKC or dumping the eeprom from a skoda fabia mk1 instrument cluster?
    This is a VDO cluster but has no direct k-line interface (it is interfaced with can-bus via a concentrator).
    via the obd2 port i've tried
    kw1281test - unable to unlock the eeprom for reading as it does not have the correct seed key alg
    vag k-commander - can read a small amount of the eeprom but fails after 0x48
    I'm using an FTDI based interface.
    any tips would be appreciated - likewise any hints at the right algorithm for the seed challenge/response.
    Justin
    Oct 2020
    Bulgaria
    Why not try to read eep direct?
    Jul 2018
    Prosaically because at the moment I'm in the UK (where the car is) and my electronics bench is in France!
    I took the cluster to bits today and could not see any eeprom chip on the back side of the board. Access to the front is severely impeded by the dials. No clear way to take them off without making a mess.
    hello,
    what year is the car ?
    are you sure there is no k line ?
    Jul 2018
    2006 registration
    No sure 100% about kLine but there is none showing on the pinout
    you are right
    sorry l thought to a other model
