Results 1 to 10 of 10
    Nov 2022
    Default Focus immobilized P1260 how to reset?
    I now have P1260 dtc on my ford focus 2010 1.6tdci UK, forscan says its immobilized, how do I reset it?
    The key has snapped
    I only have standard forscan.
    Nothing has been replaced(except battery), instrument cluster joints resoldered, but engine malfunction light is still on
    It will not turn over, no clicks, but battery is new
    Nov 2017
    Dobruja
    Key was snapped? Meaning what? Maybe needs dash & ecu resync because of battery loss. If key was snapped(brocken transponder), get a new ID63 transponder, incode-outcode sw and solve it with forscan.
    Nov 2022
    the key blade snapped about 3mm from the end
  4. The Following User Says Thank You to alafant For This Useful Post:
    volodin69 (11th March, 2023)
    Nov 2017
    Dobruja
    Quote Originally Posted by alafant View Post
    Has no relation to dash immo LED. Try relearning the 2 keys, or get dump from dash and ecu here, and you will get them resynced.
    Nov 2022
    I've only got one key.
    With changing batteries,and alarm going off etc, also got B1600 dtc
    There must be an easier way to reset this theft alarm
    I dont trust myself to erase keys and relearn with forscan
    rafal's Avatar
    UK - PL
    you need add 2nd key and forscan will do well
    Nov 2022
    So I just buy a new key, get it cut, then I can do all programming myself with Forscan?
    Do I need extended licence for forscan?
    Nov 2017
    Dobruja
    No. You can get a supertransponder from xhorse, make it id63 with minitool vvdi, and just replace it into the key location when programming it. Don't need another key and blade.
    After that, you can reset that transponder and use it other times.
    If you have forscan trail expired, you need reactivation, or extended license.
    Also, you need an incode-outcode sw for ford.
    You need to erase existent transponders and add again the existing transponder and the new transponder. Ford needs 2 transponders to be learned i.o. to start the car.
    Good luck.
  10. The Following User Says Thank You to volodin69 For This Useful Post:
    alafant (12th March, 2023)
  11. #9
    Nov 2022
    I got it to work now, thanks for all your help
  12. #10
    and what was the problem?
    for an other who experience the same.
