Results 1 to 15 of 15
    bladymir's Avatar
    Dec 2016
    Spain.Malaga
    Default Winols 2.24 scripts folder location.
    Hello friends. I have a question about winols scripts.
    I have version 2.24 and I'm making scripts for future work. To my surprise, none have been saved in the Scripts folder, but when I create it in Winols itself, it shows me all the scripts I've made. I've searched all the folders and can't find anything.
    Can someone tell me where they are kept? thank you.
    Feb 2010
    WALES
    Quote Originally Posted by bladymir View Post
    C:\Program Files\EVC\WinOLS\skript
    wbr
    Change address here:
  3. The Following User Says Thank You to shooting For This Useful Post:
    budata (12th March, 2023)
    bladymir's Avatar
    Dec 2016
    Spain.Malaga
    Hi m8.
    Thanks for your answer, I have searched all the folders and there is no file.
    I have changed the destination folder and it doesn't work either.
    It's interesting because when I save the script I see all the scripts made before, but there is nothing in the folder.
    What can be?
    Feb 2010
    WALES
    Hi m8.
    What can be?
    Ok, I see your problem, your HD is in one language and WinOLS is in another.
    In winOLS rename "Program Files" to "Archivos de programa"
    Another way is to create a directory called "C:\Program Files\EVC\WinOLS\skript"
    wbr
  6. The Following User Says Thank You to shooting For This Useful Post:
    bladymir (13th March, 2023)
  7. #5
    bladymir's Avatar
    Dec 2016
    Spain.Malaga
    hello.
    thanks shooting for your help.
    After so much research, changing destination folders and renaming them, I see that it always saves files in the same place, no matter what address it indicates, and I can't change anything.
    Documents\Evc\WinOLS
  8. #6
    Feb 2010
    WALES
    hello.
    These aren't your scripts, they are your tunes .OLS files.
    Scripts locations are as I've already described
    wbr
  9. #7
    bladymir's Avatar
    Dec 2016
    Spain.Malaga
    then I do not know.
    when creating a new script, script folder is empty, and folder in Documents increases with a new file.
    I'm already confused.
  10. #8
    Feb 2010
    WALES
    then I do not know.
    When you say "Script" what are you doing?
    Do you just mean new tune?
    wbr
  11. #9
    bladymir's Avatar
    Dec 2016
    Spain.Malaga
    https://www.youtube.com/watch?v=AIfgqeTUFRw
    I do the same.
    It is in another language but you can understand it by looking at it.
  12. #10
    Feb 2010
    WALES
    I do the same.
    Ok, I see your problem.
    You need to change the "Save" directory to "C:\Program Files\EVC\WinOLS\skript" not just click "Save"
    your config is not set to "C:\Program Files\EVC\WinOLS\skript" by default.
    In Configuration, top directory option, select the three dots "..." and select the "C:\Program Files\EVC\WinOLS" folder.
    wbr
  13. #11
    Feb 2010
    WALES
    Just had a thought, are you using Windows10 ?
    wbr
  14. #12
    bladymir's Avatar
    Dec 2016
    Spain.Malaga
    Quote Originally Posted by shooting View Post
    wbr
    Yes,but i Wind 8 the same problem
    only work good in another laptop with Windows Xp and Winols 1.7
  15. #13
    Feb 2010
    WALES
    Ahhhhhh OK!!! yes! you will not have permission to save into scripts folder.
    Save your scripts into Downloads directory then rename as "*.winolsskript" then move to "C:\Program Files\EVC\WinOLS\skript" manually
    wbr
  16. The Following User Says Thank You to shooting For This Useful Post:
    Hayssam1 (4th September, 2023)
  17. #14
    bladymir's Avatar
    Dec 2016
    Spain.Malaga
    Thank you very much m8 for your advice.
    Once again I have tried to indicate a destination folder and I see that the folder is full of files, but entering the folder there is nothing.
    I think that a good solution will be to buy an original Winols.
    Thank you very much and see you soon.
  18. #15
    Feb 2010
    WALES
    No problem, but any version of WinOLS will have the same issue in Windows10
    You can change permissions in Scripts directory, this should fix your issue
    wbr
