Results 1 to 13 of 13
    Mar 2016
    Default Help AcDelco e83
    I need help.
    After programming the car does not start.
    I used I/O Prog.
    Maybe I'm doing something wrong. Maybe someone knows a solution for the lambda catalytic converter off??
    Please help
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by Azzurro View Post
    I need help.
    I used I/O Prog.
    Please help
    Io terminal doesn't correct the cks in flash.....
    Have you correct it before write???
    Mar 2016
    the sum was also recalculated but nothing helped.
    When I upload org flash, car start.
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Do you have any dtcs???
    Mar 2016
    Yes P0601-00
    Nov 2017
    Dobruja
    Iot was not used correctly when cloning. You don't need checksum when cloning with ioterminal.
    Mar 2016
    I don't clone. I need lambda cat off
    filutek's Avatar
    Silesia
    ....cksm....
    IMMODATA ACDelco EXX<=>BCM / BCM MERIVA B REPAIR. ALL CRC-I see it ...
  9. The Following User Says Thank You to filutek For This Useful Post:
    Azzurro (14th March, 2023)
  10. #9
    Mar 2016
    I have the same bin file and it doesn't work
    I do not know why
  11. #10
    Mar 2016
    Problem solved. The problem is in I/O PROG, I programmed KESS and it works.
    Thank you all for your help
  12. #11
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Great clone........
  13. #12
    Nov 2017
    Dobruja
    IO Prog... good deal. )))
  14. #13
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by volodin69 View Post
    Yes..... very good.....
    And good feedback too......
  15. The Following User Says Thank You to Panathaole For This Useful Post:
    volodin69 (19th March, 2023)
