Results 1 to 15 of 15
Thread: pcm tuner crack
    Feb 2017
    Default pcm tuner crack
    pcm flash 1.2.5 (tuner pcm) lien de téléchargement de la version de crack si cela ne permet pas de passer. Version good no problem
    for unofficial version and therefore not activatable by the manufacturer... this cracker version needs the dongle and the box obviously.
    https://wx.mail.qq.com/ftn/download?...6f7f4627&from=
  2. The Following 4 Users Say Thank You to Merco97 For This Useful Post:
    Bahar (14th March, 2023), hovic (27th March, 2023), miroopel (17th March, 2023), Tommeke (14th March, 2023)
  3. #2
    Tommeke's Avatar
    Sep 2022
    belgium
    Thx verry much
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by Merco97 View Post
    pcm flash 1.2.5 (pcm tuner) crack version download link if it helps no pass. Version good no problem
    need dongle to run?
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by Panathaole View Post
    need dongle to run?
    I can tell more...........
    All ecu litsens in dongle not in proramm .
    And if look at better in arhive inastallation video , in here dongle !
    So..........this thread about nothing !!!
    Feb 2017
    [QUOTE=Panathaole;4507617]besoin d'un dongle pour fonctionner le dongle du pcm oui mais pas besoin d activation
    Feb 2017
    Quote Originally Posted by brend View Post
    Je peux en dire plus ...........
    Tous les ecu litsens en dongle pas en proramm.
    Et si vous regardez mieux dans la vidéo d'installation de l'archive, ici le dongle !
    Alors......... ce fil pour rien !!!
    oh no I don't agree with you my friend, you actually need the dongle but the difference is that there is no need for activation which is very practical since the majority of flash pvms are clones and cannot be officially activated I am an example...
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    If this sw need dongle, is useless like brend said....
    Feb 2017
    Si ce logiciel a besoin d'un dongle, il est inutile comme l'a dit Brend...
    look at what I wrote above... the pcm tuner must be activated with the serial number from the manufacturer... if not original, no activation... here is what my software is for...
  10. #9
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Ok.... lets see.....
    can i use this software to read write ecus?????? ( i don't have dongle......) but i have SM2 pro, that works perfect with pcmflash......
    the software will run???
  11. The Following User Says Thank You to Panathaole For This Useful Post:
    brend (14th March, 2023)
  12. #10
    Feb 2017
    Ok... voyons voir...
    puis-je utiliser ce logiciel pour lire écrire des écus ?????? (je n'ai pas de dongle ......) mais j'ai SM2 pro, qui fonctionne parfaitement avec pcmflash ......
    le logiciel fonctionnera ???
    I can't tell you... try it, you risk nothing
  13. #11
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    But that's what I'm trying to find out...... is there any chance it will work without the dongle??? if yes i should try it, otherwise why waste my time???
  14. #12
    Feb 2017
    Mais c'est ce que j'essaie de savoir...... y a-t-il une chance que cela fonctionne sans le dongle ??? si oui je devrais l'essayer, sinon pourquoi perdre mon temps ???
    I understand. but in fact this software is for clones of the pcm flash that come with the dongle, because when you buy the pcm flash you have to unlock it by providing the serial number of the device for it to work. it is not a software that allows you to use the program without a device... example: how could you use a kess or a ktag if you only have the software and no device...?
  15. #13
    brend's Avatar
    Oct 2015
    Same where
    Around and around ..........
    All answer in my # post 4 !!!
    Of course this without risk's , because this just no start without dongle , that's it !!!
  16. #14
    Jun 2013
    EU
    Maybe you can write in an even shorter size, maybe then we all can directly throw your messy to trash bin without loosing our eyes trying to read it. Also grey over grey is a very good colour combination you have chosen. Did you make it on purpose?
  17. #15
    Oct 2020
    The link is not working.
