need this pass please
any one have a working link for mpps v16 please, lost the disc for mine new laptop cant use it now preferable without loader![]()
Hi.
Here you have without a loader.
Anyone got a tip on how to start MPPS? I've tried with both clean installed Windows XP and Windows 7 on VirtualBox. Both options just "blinks" for a second without MPPS starting.
Connect mpps to usb and startIt wont work with tool disconnected, i think its your problem
aottesen (23rd August, 2018)
That my good Sir, THAT did the difference!! :-D
HI,
i have V13(SE74) --> is it it safe to flash edc16 (passat 1.9 PD 105hp)m - reading was no problem - got 2048KB tried 3times and did filecompare -> OK
No
need genuine tool....
Hello guys, hope someone can help me out...
I just got the MPPS V16 (clone) and i´m trying to read an ECU ME1.5.5 but i´m getting 2 errors:
One is: "Maximum Number of attemps reached" (cant remember the exact error words now, but is something like this)
The other is: "Invalid Key"
When i do the ECU INFO (F1), it gives me the VIN number and version, but when i press "Read" (F2), i get these errors...
Sometimes its the 1st, other times its the 2nd one.
And it always gives me the "Error Windows" to send Log.
Can anyone tell me that this might be?
I already tried several times to read this ECU with Kess V2, but i cant read it...
This is from a Mexican Chevrolet Model (similar to EU Opel Corsa C 1.6 8V)
If anyone can give me some tips i would really appreciate...
Just Consider helping Freely like I want to do...
Thanks and Rep are Always Welcome...
mpps 13.02 vs mpps 16?
I have a VW T5 1.9 TDI from 2008 102 PS with EDC16U34, MPPS 16 writes, the ECU is protected, how can I read the flash?
I can screw and diagnose, for chiptuning I need your help
Somebody have the solution for unlock MPPS v18 ?
BR,
Carradio2001.
Somebody have the solution for unlock MPPS v21 ?
I had bought version 21, it worked (but not correctly)for about 10 times and suddenly it goes .... (time bomb)
I sent it back, bought a European clone and calmed down ....
(works almost flawlessly)
This forum has taught me a lot since I am a member and found the community to be very helpful, so I would like to return the favor with what I can.
Seen users asking for MPPS V16 that works on Windows 10.
I have the attached version working on my Windows 10 64bit laptop without an issue.
Just copy the "MPPS" folder in your C:/ directory, plug your MPPS V16 interface, run "64 Bit Driver Installer.exe" found in "Device Driver" folder and then you are good to go.
Worked for me on a couple of laptops without an issue. Not sure if its different than the other copies posted by other users, I am just uploading it as this one is tried and tested.
Its not password protected for everyone to enjoy.
If it helped you, say thank you!
AGK (21st December, 2023), BUSCADOS (18th August, 2021), fabiof1 (30th August, 2021), kido resuri (11th October, 2022), mesa31 (21st September, 2021), qeen (1st May, 2024), TKX (17th April, 2025), tonimq (30th June, 2021), tunedigging (5th March, 2024)
