Results 1 to 3 of 3
    Jul 2014
    Romania
    Default panasonic toughbook fz-55 bios password reset
    Hi.
    Someone can help me with panasonic toughbook fz-55 bios password reset
    bios bin in attache
    Jul 2014
    Did You find a solution? I have a fz-55 with bios password, and need someone who are able to remove
    Jun 2024
    Default ItÂ’s not impossible but good luck
    Quote Originally Posted by kocka104 View Post
    Hi Kocka, Check this video, and make your choice.
    https://youtu.be/ReZLfTyBd4w
    The other option is to send the computer to Panasonic, who will offer to change the motherboard.
    If your goal is simply to reinstall Windows.
    As a last resort, you can try to delete all the data on the disk. To do this, hold down the shift key when you reboot the system and launch console mode. You do a diskpart then select disk 0 (usually) which is the OS primary disk, then depending on your needs you do a convert MBR or GPT and exit, exit.
    With a bit of luck, the PC will boot on your installation key. If not, test an installation with the Ventoy utility, which allows you to bypass the secureboot.
    Good luck for the rest.
    Cheers.
