Results 1 to 12 of 12
    Bulgaria
    Default Lexus LS 460 airbag reset 89170-50J50
    Hello, can you help me?
    I need reset airbag ECU Lexus LS460 ,
    Toyota 89170-50J50
    93c86
    dump in attachment.
    Thanks in advance
    slick_dick's Avatar
    Essex
    here you go try this
    pass in pm
    br
    slick
    “There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
  3. The Following User Says Thank You to slick_dick For This Useful Post:
    jordanhdd (21st March, 2023)
    Bulgaria
    I write new cleaned file and install the SRS ECU , but the light still on.
    When I read, does not have the errors.
    Is there a procedure after installing the SRS unit?
    Joepodhale's Avatar
    Mar 2023
    tray and send results
    It would be nice if you could press the magical button THANKS+REP for your help.
  6. The Following User Says Thank You to Joepodhale For This Useful Post:
    jordanhdd (23rd March, 2023)
    Bulgaria
    I install SRS unit with new file.
    When the car is on ON ignition position , doesn't have a error , but when I start the engine and turned off , after that have a error B1000 Airbag ECU Malfunction.
  8. #6
    Joepodhale's Avatar
    Mar 2023
    Quote Originally Posted by jordanhdd View Post
    upload the original file and check the dtc
  9. The Following User Says Thank You to Joepodhale For This Useful Post:
  10. #7
    Bulgaria
    I tried the original file first and deleted all the errors.
    When I check with the diagnostics I can't find any crash data or errors saved but the light is still on, because of that I uploading the file.
  11. #8
    Joepodhale's Avatar
    Mar 2023
    I think the file is not original it has been modified before
  12. The Following User Says Thank You to Joepodhale For This Useful Post:
  13. #9
    Bulgaria
    What can I do in this case?
  14. #10
    Joepodhale's Avatar
    Mar 2023
    ask for the original file maybe someone has
  15. The Following User Says Thank You to Joepodhale For This Useful Post:
  16. #11
    Bulgaria
    I found the problem. When I read the original file into the software, the swap option was added by default. I do not know why. Thank you very much. Your solution works.
  17. The Following User Says Thank You to jordanhdd For This Useful Post:
    Joepodhale (23rd March, 2023)
  18. #12
    Joepodhale's Avatar
    Mar 2023
    I'm glad you managed to solve the problem​.
