Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    Nov 2019
    Default Chevrolet Spark CONTINENTAL D52 IMMO OFF
    Hi friends, is possible tested solution for remove immo in this ecu Continental D52 chevrolet spark?
    ID: HW_5WK1K11A SW_D12B00
    I bought a new key from opel but they no longer have the old diagnostic tool to code it...
    I saw that there were solutions to remove the immobilizer on the FLASH AM29F400BB that I attached here.
    thanks in advance
    IMM0killer's Avatar
    May 2019
    Sometimes in eeprom , Sometimes in flash
    here
    checksum ok
    press thanks & reputation
  3. The Following 25 Users Say Thank You to IMM0killer For This Useful Post:
    Abacotv (8th January, 2025), ascotauto (10th April, 2025), boxsport (28th October, 2024), DjRado (5th February, 2025), ecufix (9th January, 2025), guillermemosz (20th November, 2024), habib87 (28th March, 2023), herberthan (20th January, 2025), jcdiag (14th October, 2024), juank1 (14th November, 2024), jupteck (5th November, 2023), kevinstone2010 (21st November, 2024), Kfoury (4th May, 2023), la2p (29th January, 2025), lizardking6901 (31st January, 2025), PEACHY46 (28th November, 2024), Slav1984 (20th June, 2024), spike84 (22nd March, 2025), weza247 (10th January, 2025), zizzou123 (26th March, 2024)
    Nov 2019
    thank you friend for your responsiveness. I inject the file but the red light is still flashing. and no start
    IMM0killer's Avatar
    May 2019
    did you follow my instruction in the archieve?
  6. The Following User Says Thank You to IMM0killer For This Useful Post:
    Nov 2019
    excuse me I had not seen the text file... it works perfectly thank you!!! just a quick question, I no longer have communication with the computer via the OBD socket and there is the engine light on.
  8. #6
    IMM0killer's Avatar
    May 2019
    good to hear mate
  9. The Following User Says Thank You to IMM0killer For This Useful Post:
  10. #7
    Nov 2019
    would you have an idea of ​​why I no longer have communication via the obd socket to remove the engine light? THANKS
  11. #8
    Nov 2019
    Problem solved. when you disconnect the antenna from the key neiman, you no longer have access to the engine computer via the obd socket... so I reconnect the antenna, erase the DTCs and disconnect the antenna again, the light is gone. if it ever serves you one day you know. Thanks for helping me
  12. The Following User Says Thank You to habib87 For This Useful Post:
    volodin69 (28th March, 2023)
  13. #9
    Aug 2019
    Bulgaria
    Quote Originally Posted by habib87 View Post
    Connect pin 5 and 6.
  14. The Following 3 Users Say Thank You to miroopel For This Useful Post:
    ecufix (25th January, 2025), habib87 (7th April, 2023), volodin69 (28th March, 2023)
  15. #10
    Nov 2019
    Quote Originally Posted by miroopel View Post
    Hi, thank you for your reply. do you have to connect the wire to the immobox socket? and leave the plug unplugged.
  16. #11
    Nov 2019
    Hello everyone, I managed to remove the DTC but the speedometer still does not work. anyone have an idea? thank you
  17. #12
    Jan 2020
    HELLO,
    CAN YOU SEND PIN KEYPASS?
  18. #13
    Feb 2022
    hi it is possible to Disable immobilizer Jeep 2007 Cherokee 4.7 computer P05094354AD / ECU MOTOROLA NGC4 / ECU
  19. #14
    Sep 2023
    password,, thanks
  20. #15
    IMM0killer's Avatar
    May 2019
    please
    dont ask password if you dont read first post well..........
