Results 1 to 7 of 7
    Jul 2013
    Germany
    Default Iveco Daily 150kW EDC17C49 AdBlue off
    can somebody make AdBlue off from this Iveco Daily 3.0 150kW with EDC17C49 0281030088?
    DPF is still inside, so only AdBlue off.
    OBD read with Kess3 attached.
    Thanks and Regards, AudiRS
    Aug 2015
    GB
    Quote Originally Posted by AudiRS View Post
    Here your file....Gl.Br
  3. The Following User Says Thank You to dedadraz For This Useful Post:
    AudiRS (2nd April, 2023)
    Nov 2022
    hello can you remove adblue for me on iveco daily edc17c49
    Member YougNord's Avatar
    Apr 2020
    possible to remove adblue for this edc17c49 yes
    Apr 2016
    When remove adblue , need remove dpf also to not get problem later , if not after a moment car goes on limp mode
    Apr 2020
    Quote Originally Posted by ghassen View Post
    That`s completely incorrect..., when solution is manual and good no problem for dpf system, this happens when you use automatic programs..
    Apr 2016
    Not because manual or automatic solutions, because if remove adblue mean no urea injected , no regeneration... etc More soot will be accumulated on dpf sensor ... Edc will read high value of pollution and car go to limp mode
