Results 1 to 11 of 11
    Feb 2017
    Italy
    Default Jlink - Jtag to read SPC560P50 fiat 500L pinout wiring
    Hi my friends...
    I'm crazying...
    I'm trying to read ecu airbag by jlink but I have same error...
    Voltage loss 1v.
    I powered PCB by 5v external supply, but I think that Power supply must be given to airbag module 12v
    I'm searching pinout wiring connection to power this ECU...
    Help me please
    fuzz1's Avatar
    Jul 2019
    Why are you using 5 volts? Use 3.3. volts
    Feb 2017
    Italy
    Quote Originally Posted by fuzz1 View Post
    I tried 3.3v also but Is same thing...
    Software tell me that Voltage Is too low.
    Feb 2017
    Italy
    Hi guys, finally I managed to read the spc560 memory...
    error was too low voltage, less than 1 volt.
    Indeed, the Jlink, at pin 1, detects the voltage on the target.
    It is an input pin and not an output pin like pin 2.
    By connecting them both, I powered the MCU and at the same time the Programmer detected the necessary 3.3 volts.
    I hope this experience helps someone.
  5. The Following 2 Users Say Thank You to giary74 For This Useful Post:
    danielif (6th April, 2023), kophiphi (3rd February, 2025)
    fuzz1's Avatar
    Jul 2019
    I'm sorry i can't follow the explanation. Pin 1 supplies voltage from jlink?
    Feb 2017
    Italy
    no problem, I'll try to be clearer...
    the jlink did not connect because it did not detect a voltage of at least 1 volt on the device.
    The device was powered by a separate power supply.
    the J link detects the target voltage at pin 1
    instead it can power the target at 3.3 volts via pin 2
    since pin 1 didn't get any feedback, I connected pin 1 and pin 2 together so everything works.
  8. The Following User Says Thank You to giary74 For This Useful Post:
    fuzz1 (7th April, 2023)
  9. #7
    fuzz1's Avatar
    Jul 2019
    Where do you get the project files to read the modules? Can you use st link to read the ECU?
  10. #8
    Feb 2017
    Italy
    hi, it's easier than it looks...
    the software used is jflash arm and the programmer is this one in the photo.
    Once started, in project setting, CPU, choose the chip you need to read and go ahead intuitively.
  11. The Following User Says Thank You to giary74 For This Useful Post:
    fuzz1 (8th April, 2023)
  12. #9
    fuzz1's Avatar
    Jul 2019
    Thanks for the info. I saw the jlink edu and saw the st link which is extremely cheap. Was just wondering if those cheap stuff was up to the task as well.
    Also heard about project files. I guess those are just file written by the outside developers in C.
    Was wondering if there was some kind of compilation of those projects
  13. #10
    Feb 2017
    Italy
    my jlink is cheap but works very well.
    I use it to read and write chips and I don't have the need and ability to develop programs.
  14. #11
    fuzz1's Avatar
    Jul 2019
    The st link is dirt cheap. Maybe 2 USD. Some projects have already been written and saw some that have been shared on this forum itself
