    Member lemrid's Avatar
    Sep 2012
    Default Software tuning solution Recommendation
    hi,
    which is the most efficient official tuning software solution available in the market to recommend.
    the software solution should :
    - price shouldn't exceed 1k
    - support latest common cars (ecu & tcu)
    - do almost all DTC, egr, dpf, adblue SCR OFF (immo not interessted)
    - do almost Lambda, NOX & CAT off for petrol cars
    - do almost stage1 & ++, VMAx, torque adj.
    - good support.
    thkx folks.
    Jun 2020
    No software can do these things, especially remaps, you need a good tuner.
    File service, Custom Remapping, stage 1 & 2 dyno tested.
    Petrol + Diesel
    Adblue dpf egr Only tested working solutions.
    Use thanks and Rep if my help was helpfull.
  3. The Following 2 Users Say Thank You to Krisfuzzy For This Useful Post:
    bobolin4o (9th October, 2023), lemrid (8th April, 2023)
    Jul 2017
    Romania
    Quote Originally Posted by Krisfuzzy View Post
    especially for 1k
    File Service ----- Custom Files ------ DPF / SCR / EGR / TVA / Stage ...... Immo / Airbag ETC
    ​Manual File Service WITHOUT prepaid
  5. The Following User Says Thank You to cbvasoft For This Useful Post:
  6. #4
    Nio's Avatar
    There are no software can do this for 1k. Also software for 10k make a lot of mistakes and not good tuning maps. Regards.
    "IF YOU THINK PROFESSIONAL PEOPLE COST YOU A LOT, IS BECAUSE YOU DID NOT KNOW HOW MUCH WILL COST YOU AN UNQUALIFIED"
  7. The Following User Says Thank You to Nio For This Useful Post:
  8. #5
    Mar 2017
    Portugal
    Quote Originally Posted by lemrid View Post
    hi,
    - good support.
    thkx folks.
    Your Software name is:
    - FileService
    Not even Swiftec (that costs about 8k, can do it properly).
    for less then 1k it's better for u to look for a file provider and pay for the job
  9. The Following User Says Thank You to marko6jpt For This Useful Post:
  10. #6
    Jun 2013
    EU
    People still thinks that there is a one button software that makes all the job without the proper knowledge.
  11. The Following User Says Thank You to morgano For This Useful Post:
