I keep getting this P2563 error on my 1.6 tdi Leon 2012.
Have tested the turbo actuator and it holds vacuum and checked voltage at max vacuum which is at 3.5v. minimum is at 0.7v so nothing looks to be off there. Currently confused as to what could be causing it... is it a faulty turbo?
Someone suggested regenerating the dpf but by the looks of things it doesn't need to be regenerated??
Any suggestions welcome.
Code from VCDS below:
7286 - Turbocharger Boost Control Position Sensor Circuit
P2563 00 [036] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Time: 02:53:43
Engine RPM: 894.50 /min
Normed load value: 11.0 %
Vehicle speed: 0 km/h
Coolant temperature: 95 °C
Intake air temperature: 40 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.682 V
Unlearning counter according OBD: 40
Charge air pressure actuator: acknowledgment-ANG_BPA[0]: 80.487 %
Charge Pressure Actuator: activation-ANG_SP_BPA[0]: 85.001 %
High press turbocharger actuator: activation-CTL_LIM_BPA[0]: 84.998 %
High press turbocharger actuator: actual uncond volt value-V_BPA[0]: 2.568 V
Turbocharger boost control: offset open-V_BPA_BOL[0]: 0.498 V
Turbocharger boost control: offset closed-V_BPA_TOL[0]: 2.729 V < this seems to change sometimes its 2.661v one time I've seen it at 3.5v.
High press turbocharger actuator: status-LF_STATE_BPA_DISP[0]: 77
