Results 1 to 8 of 8
    Sep 2022
    POLAND
    Default VW Passat 2.0 Tdi 2007r. P1388
    Hello, I have a problem with a VW Passat b6 2007, 170km, DSG.
    I have errors:
    P1388 - Controller Fault - Electronic Throttle Monitoring (Drive By Wire)
    P3008 - Camshaft sensor (G40) - signal out of tolerance.
    The car sometimes does not respond to the gas pedal and catches a one-second lag while driving. It goes into safe mode.
    I made a clone of the new ecu and after driving 300 km only i have P1388 , but the problem is the same.
    Thanks for the help!!!
  2. The Following User Says Thank You to totem For This Useful Post:
    NiZaTroniC (25th April, 2023)
  3. #2
    Jan 2014
    morocco
    Did u manage to fix the car coz I have The same problem
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Did uou manage to fix this I jave same problem . Ppd1.2 try 2 ecus same thing
    P1388 and camshaft sensor
    Please answer
    Here to HELP!
    Top Poster MrDerv's Avatar
    Mar 2023
    UK
    Check the condition of the timing belt. The fault code usually means either the sensor is faulty, OR WORSE.... Timing skipped a tooth and camshaft now out of sync with the crankshaft.
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Yes checked but why p1388 ??
    In Neutral all o k. In reverse all o k. . When put ind Drive glow plug ligh flashes and no power shaking engine while accelerate and P1388 apears
    In both ecus
    Here to HELP!
    immokill's Avatar
    Jun 2009
    UNIVERSE
    no one has soution for this problem????????
    Here to HELP!
    Sep 2022
    POLAND
    Screenshot_2023-10-01-22-17-44-198_com.mi.globalbrowser.jpgHello, you need to check the cable harness near the starter. Check connection sensor with ecu.
    Portugal
    Can you send the chassis of the car so I can see if there is any technical information.
