Results 1 to 5 of 5
    Aug 2015
    Default Mazda 3 immo sync
    Can someone help me with this Mazda 3 1.6tdci ecu dash sync?
    It looks like the ecu's eeprom is corrupted and i tried to use another ecu's eeprom and do a module initialization with forscan but it didnt work.
    Also tried to write the ecu's immo code to the dash manually but i think it has a checksum that i cant calculate, same with the ecu.
    Thanks.
    kiszka's Avatar
    Quote Originally Posted by norbi5073 View Post
    Thanks.
    Tell me did you have to fiddle with it yourself even though you still had to put the files here
    You have made yourself difficult by messing around with forscan, because my work may not work automatically
    https://mega.nz/file/ozwC0KBS
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
  3. The Following User Says Thank You to kiszka For This Useful Post:
    norbi5073 (16th April, 2023)
    Aug 2015
    Thank you kiszka!
    To be honest i would have felt bad if i did not try everything i could do myself that i found and read on this forum.
    And i made sure to include everything that was originally on the car and wrote everything back with your file.
    Only had to match the keys back after writing your file and everything is good.
    Thank you again.
  5. The Following User Says Thank You to norbi5073 For This Useful Post:
    kiszka (16th April, 2023)
  6. #4
    kiszka's Avatar
    Thank you kiszka!
    Thank you again.
    It's true that a Pole would feel bad if he didn't try to fix it himself
    But it's good that you described what you did because I could help more precisely as far as I can at a distance
    thanks for the info
    Reality of life :
    4:Everyone lies
    Jun 2019
    Link expiried its possible have new link for Mazda 3 sync app tnks
