Results 1 to 13 of 13
    spiridonas's Avatar
    Default Citroen Berlingo 2016 1.6 bHDi EDC17C60 AdBlue OFF
    Hi friends, I need to AdBlue off from Citroen Berlingo 2016 1.6 blue HDi EDC17C60 because i have DTC: P20E8 - Pressure of the Urea Is Too Low.
    Does anyone have a working solution?
    Many thanks in advance.
    Dec 2017
    Here you have
    pass in pm
    spiridonas's Avatar
    Quote Originally Posted by jfcchipped View Post
    Here you have
    pass in pm
    Please can you share the password ?
    Luigi84's Avatar
    Dec 2022
    Italy
    Default EDC17C60 AdBlue OFF
    EDC17C60 AdBlue OFF
  5. The Following User Says Thank You to Luigi84 For This Useful Post:
    spiridonas (20th April, 2023)
    spiridonas's Avatar
    Quote Originally Posted by Luigi84 View Post
    Hi please i reset the adblue and unplug adblue main connector and i writing your file
    and i have this dtc :
    P1435
    U1400
    Please can you fix ? Thanks
    Inquizit0r's Avatar
    Aug 2013
    Ukraine
    This is your SCR OFF file.
  8. The Following User Says Thank You to Inquizit0r For This Useful Post:
  9. #7
    spiridonas's Avatar
    Quote Originally Posted by Inquizit0r View Post
    Thanks, i have this dtc :
    P1435
    U1400
    U0118
  10. #8
    baltazar3's Avatar
    Andromeda
    Quote Originally Posted by spiridonas View Post
    Here is requested file...pm
    '" live and learn........ if you wont ....you ain't "
    _______ . ____ . __ . __ . _______ . __ __ __ ... ---
    If my post was HELPFUL please push THANKS button
  11. The Following 2 Users Say Thank You to baltazar3 For This Useful Post:
    Hakim23 (19th October, 2023), spiridonas (20th April, 2023)
  12. #9
    Oct 2021
    Serbia
    here is ur file, after thanks + rep, pass in pm
    Disconnect adblue pump and adblue module!
  13. The Following User Says Thank You to LukaLP For This Useful Post:
  14. #10
    Inquizit0r's Avatar
    Aug 2013
    Ukraine
    Same pass. DTC OFF
  15. The Following User Says Thank You to Inquizit0r For This Useful Post:
  16. #11
    spiridonas's Avatar
    Quote Originally Posted by baltazar3 View Post
    Hi many thanks, I tried your file the car no start and i have this dtc :
    P1435
    U1400
    U0118
    Maybe my tool no cs corrected.
    Can fix and cs ?
    Disconnected only adblue pump.
    Where is adblue module ?
  17. #12
    rm23's Avatar
    UK
    adblue off for you....
  18. The Following User Says Thank You to rm23 For This Useful Post:
  19. #13
    Jun 2020
    P1435
    U1400
    U0118
    Can fix and cs ?
    The codes P1435 U0118 detected refers to the diesel additive pump, not to the adblue pump.
    The cerina is missing, and after inserting and reassembling everything you have to give the control unit the command to replace the dpf and the car will start again!
    The code U1400 LIN data bus - communication error Possible causes Wiring Alternator Engine management calculator
    File service, Custom Remapping, stage 1 & 2 dyno tested.
    Petrol + Diesel
    Adblue dpf egr Only tested working solutions.
    Use thanks and Rep if my help was helpfull.
