Results 1 to 12 of 12
    Feb 2015
    Lincolnshire
    Default 2016 Ford transit custom alarm active akl PROBLEM
    Struggling on this one. 2016 transit custom, alarm active. Tried lonsdor no comms, autel no coms. Ids and fdrs no comms when trying to delete or add keys.
    Can the bcm be virginalised and programmed back in with fdrs? Or can we edit eeprom on bench to disable alarm?
    whats the options
    system is id63
    many thanks
    Stop getting worried about what could go wrong, and start getting excited about would could go right!
    hmmmmmmm........eeprom
    Digi v4.94, Xtool, R260, R270, Smok, VagProg DataSmart 3+ Smelecom, Autel Maxisys ms908, SpeedFilters
    super jumbe's Avatar
    Livingstone
    No com usually fuse blown, have checked all the fuses?
    Feb 2015
    Lincolnshire
    Quote Originally Posted by super jumbe View Post
    yes all fuae are ok. Only get no comms when try to add/delete keys, get full comms when diag the bcm
    Mar 2018
    UK
    You don't have propre tool for this job
    you need tools like AVDI or SmartPro
  5. The Following User Says Thank You to Manta1600 For This Useful Post:
    p1et (27th April, 2023)
    Feb 2015
    Lincolnshire
    Quote Originally Posted by Manta1600 View Post
    ford say not possible 14-16 alarem active, need to renew bcm or replace.
    anyone know how to renew bcm?
    part number BK2T-14B476-CU
    Mar 2020
    in the field
    motorcraft service as built
    maybe try with this +fordscan
    scotland clydebank
    2014 and 2016 alarm active not possible this is according to Chris as did ask some questions with truecode Ford and said cannot comunicate if alarm active and new bcm is needed as Ford said .
    Dec 2010
    Nottingham
    smart pro has an alarm active option , with avdi if you have FR010 you may be able to reset to as built and add key then reset system.
  10. The Following 2 Users Say Thank You to rapidlocksmiths For This Useful Post:
    godfathertre (1st May, 2023), Manta1600 (1st May, 2023)
  11. #9
    scotland clydebank
    Are you sure is 2014 and 2016 as read everywhere not possible for these year and new bcm from Dealer if alarm active.
  12. #10
    Dec 2010
    Nottingham
    ive not tried it with smart pro , but on AD mykeys it tells you if AKL and alarm active on 2014 to 2016 to use the all keys lost option
  13. #11
    Apr 2019
    manchester
    Did you have to replace the bcm or did you find a tool that can do keys if the alarm is active IV got a 2016 custom all I have tried avdi fdrs and a few others and they make you wait for 10 mins the horn beeps 2 times then the next message says turn off ignition and says incompatible software version
  14. #12
    Oct 2017
    Smart pro can do it.
    I had a same situation 2 weeks back.
    Avdi, tdb, lonsdor failed but SP solved the problem.
