Results 1 to 2 of 2
    Oct 2018
    Romania
    Default Ford denso sat nav - Visteon CD132-NAV MODULE 5S7T-18B988-AF
    I want to switch on the bench this sat nav CD132-NAV MODULE 5S7T-18B988-AF made by Visteon.
    I already have used 2 x +12V and 2 x -12V wires as indicated on the attached picture, but the unit is not switching on.
    I know that the screen module (second/middle) plug needs also at least a plus wire. Can someone help with a wire diagram about the right connection for the screen module or maybe to indicate where to add +12V ?
    Decode Ghost's Avatar
    Aug 2015
    Quote Originally Posted by workbattery View Post
    To operate this device outside, you need to make a compatible simulation circuit. This device only works in its own Vehicle.
  3. The Following User Says Thank You to Decode Ghost For This Useful Post:
    shooting (9th May, 2023)
