Results 1 to 15 of 15
    Jan 2014
    Post KESS KTAG SD CARD UPDATE easy way
    Hello guys,
    i'm sharing a faster and easy way to update or create a new SD card on kess 5.017 and ktag 7.020.
    basically you just need to format FAT32 the sd card you want to put in kess/ktag and copy the files above to the update folder of each ksuit. then open the ksuit 2.80 for kess and 2.23 for ktag and it will update immediately. it's all.
    inside the folder is an app to format the SD card.
    i recommend sandisk/samsung/kingston genuine cards. class10 cards nowadays are cheap (although kess and ktag the faster they can read is class4)
    Pass: ka0s2023
    enjoy
  2. The Following 39 Users Say Thank You to elioc9 For This Useful Post:
    29f001 (15th October, 2024), arwers (21st August, 2024), AvechuchoAxel (23rd October, 2024), azedine1 (13th March, 2024), boris2005 (23rd August, 2024), carcode (5th August, 2024), cl55 (12th August, 2024), eddieddi (20th November, 2024), electronicdeivi (3rd June, 2024), emin carman (1st August, 2023), enigmaelectroni (9th May, 2023), Gery (15th September, 2024), jaykh136 (3rd September, 2024), Jean6marc (26th December, 2024), jerrygera (24th May, 2023), kuchka (18th January, 2024), mALOzLO (25th November, 2024), master00007 (21st November, 2023), Mauri93 (14th February, 2024), meansure (21st February, 2025), MishaNew (12th March, 2025), misterfixitmd (26th June, 2023), mukika09 (11th April, 2025), PACEVE (17th September, 2024), PEDRO4053 (22nd March, 2024), pipiskyr (2nd December, 2024), Sansoni (11th May, 2023), Sanyo320 (7th April, 2024), Sefior (8th May, 2023), sehack (29th August, 2023), Shield (26th May, 2024), Solafe89 (19th January, 2024), Troco5773 (8th July, 2023), urbajs (11th September, 2023), zemaitaitis (14th May, 2024)
  3. #2
    Jul 2018
    Quote Originally Posted by elioc9 View Post
    Hello guys,
    i'm sharing a faster and easy way to update or create a new SD card on kess and ktag.
    basically you just need to format the sd card you want to put in kess/ktag and copy the files above to the update folder of each ksuit. then open the ksuit 2.80 for kess and 2.23 for ktag and it will update immediately. it's all.
    PM for pass after thanks and rep.
    enjoy
    pm me with pass please
    do the files also work with ktag 2.25?
    also, you should mention what type of format? fat32?
  4. The Following User Says Thank You to Sefior For This Useful Post:
    adyspy (8th September, 2024)
  5. #3
    Jan 2014
    fat32. yes works with 2.25 ktag
  6. #4
    Nov 2017
    Dobruja
    I had that too, not from you. I just f...ked up my ktag with it. Seriously? Wake up err on a lot of ecus. Is ok i have nxp and the other dumps for it and restore it. Before using it, check your kess or ktag fw.
    Jun 2013
    EU
    Posted here loooong time ago mate.
    https://www.digital-kaos.co.uk/forum...-a-new-SD-card
    Regards,
  8. The Following User Says Thank You to morgano For This Useful Post:
    bergbahn (13th May, 2023)
  9. #6
    Jan 2014
    Quote Originally Posted by volodin69 View Post
    on my devices worked pretty well, but they are reworked. maybe thats the difference
    Quote Originally Posted by morgano View Post
    Regards,
    i've seen that thread but its a bit confusing, created this one because saw it this simple way on another forum. if is useless moderators can delete it. just tried to make things easier.
  10. #7
    Jun 2013
    EU
    Can’t be easier than dropping files on update folder mate. The only thing is that the original thread has many other manual methods and info. But if you read carefully first post of thread all is clear.
    files for update folder originally posted by members DigitalUnder and me on that thread as i said looooong time ago.
    No need re upload pass protected. As it is open on original thread.
  11. The Following User Says Thank You to morgano For This Useful Post:
  12. #8
    Jan 2014
    I shared the pass, now its available to everyone.
  13. The Following User Says Thank You to elioc9 For This Useful Post:
    morgano (9th May, 2023)
  14. #9
    Jun 2023
    thanks i sure hope to be able to download this sometime
  15. #10
    Feb 2024
    i tried to update the Kess v2 5.017 with this software dedent went quit well because the update stops nearly at the end?
    any suggestions
  16. #11
    Jun 2024
    Default trying to download
    anychance of an external link struggling to get the permission for the download fair enough if its not allowed
    Hello guys,
    Pass: ka0s2023
    enjoy
  17. #12
    Oct 2023
    sudan
    thanks YOU brother I have version 2.25. Can I update it to 2.70 or 2.80 with this file?
  18. #13
    Aug 2024
    Hi Elioc9, would you please assist me with the files or send me in the right direction to get these? Struggling with wake up error code on my newly purchased Kess V2.
  19. #14
    Aug 2024
    Default Please attach file
    Hello guys,
    Pass: ka0s2023
    enjoy
    Please attach file
  20. #15
    Sep 2024
    would this fix wake up error i keep getting? also how do i get the files it wont allow me to download them
