Results 1 to 1 of 1
Thread: BMW ETK 2020-01
    Apr 2021
    Default BMW ETK 2020-01
    I found on another forum, a multilingual BMW ETK with a base 2020 + motorcycles. I tested it on Win 7/10 it works fine but for Win11 there are some graphical glitches so I don't recommend using it on win11. A little instruction if anyone had problems running it after installation.
    Installation
    Tomcat - change the ports to these
    application port - 1027
    shutdown port - 1028
    password for RR is oxford12.
    password for ZINORO is shenyang15
    Company
    Copy the javaclient to
    C:\BMWgroup\ETKLokal\javaclient\classes
    Also, in order to run ETK properly, you need to install jdk-8u92, which is located in the ETK folder, and make sure that Java is installed in both directories - ProgramFiles and ProgramFiles(x86), if not, copy the java folder from ProgramFiles to ProgramFiles(x86).
