Results 1 to 15 of 26
    S0nda's Avatar
    Nov 2021
    Reading....
    Default PcmFlash original - share experience.
    Im owning Autotuner master and Pcmflash.
    I have purchased many modules, i use it as secondary tool which until now worked perfect... using scanmatik 2 pro.
    Modules i have tested :
    1. Module 71 - edc17med17 works on every ecu - until now never fails.
    2. Module 77 - on med 9.5 - bmw edc16 - vag edc16 many type of ecus - never fails.
    3. Module 58 - dsg / dsq250 some types obd/read write - never fails.
    4. Module 57 - pcr2.1 unlock / read and write works perfectly.
    5. Module 50 - all vag edc17 works perfectly ( edc 17 / VR - write )
    6. Module 54 - vag dcm 3.7 on polo 1.2 works perfectly.
    7. Module 65 - this module also works perfect, never fails.
    Please share your experiences, we can easy in future know what ok what not.
    I use it as secondary tool - because one time buy modules and never pay anymore.
    Thanks.
    Autotuner Master - FLEX Master - DFOX Master (DFBtechnology) PCMflash 1.3.8 - VCDS hex v2 - Scanmatik 2 pro - Launch - Odis
    "clones" -> Ktag - Kess v2 - Mpps v22 - FGtech - Inpa -
    WinOLS 5
    IF helped! Press "Rep & Thanks"!
    Jul 2022
    Many times used module 71 with no problems. I heared bad clones also working good to time when transistors will be broken (pcmtuner).
    Who use module 84 for dcm6.2v? I want to buy it.
  3. The Following User Says Thank You to sebol1204 For This Useful Post:
    S0nda (17th May, 2023)
    S0nda's Avatar
    Nov 2021
    Reading....
    Quote Originally Posted by sebol1204 View Post
    I have purchased.. but still did not tried it
    Also they relased to read on bench mode real read.
    For vag group.
    WinOLS 5
    Jul 2022
    Quote Originally Posted by S0nda View Post
    For vag group.
    That's why i want to buy it. But writing working only in OBD - i'm afraid when something will be wrong and ecu will be bricked i can't repair this. I don't have flex for recover in boot mode
    S0nda's Avatar
    Nov 2021
    Reading....
    Pcmflash does it by bench see module 84
    https://pcmflash.ru/downloads/pcmflash_84.png?100
    WinOLS 5
    skywoker's Avatar
    May 2012
    ROMANIA
    Only for read, not for write !
    <a href="https://www.evc.de/en/check_evc_license.asp?k=to5BfjHPlwobCIDYikhVnw%3d% 3d" target="_blank"><img src="https://www.evc.de/common/check_evc_license_image.asp?k=to5BfjHPlwobCIDYikhV nw%3d%3d"></a>
    S0nda's Avatar
    Nov 2021
    Reading....
    Quote Originally Posted by skywoker View Post
    Not sure
    Still did not tried, but dcm6.2 is reliable ecu for tuning
    Did some with AT but not pcmflash.
    WinOLS 5
    Jul 2022
    Not sure
    Read - bench, VR
    Write - Only OBD
  10. #9
    mexanico1971's Avatar
    portugal
    Read - bench, VR
    Write - Only OBD
    Module 87 ?
    Were do you buy it ?
    Thank"s in advance
    My work is my life ART TECH GARAGE
  11. #10
    S0nda's Avatar
    Nov 2021
    Reading....
    Quote Originally Posted by mexanico1971 View Post
    Module 87 ?
    Thank"s in advance
    I have purchased it from a private guy which is a official reseller
    WinOLS 5
  12. The Following User Says Thank You to S0nda For This Useful Post:
    mexanico1971 (19th May, 2023)
  13. #11
    brend's Avatar
    Oct 2015
    Same where
  14. #12
    brend's Avatar
    Oct 2015
    Same where
    Job with genuine scanmatik 2 pro ...............
    Obd2 work , no problem .
    Work virtual file away .
    In bench not tested , but I think also work ok .
    Module 87 ?
    Thank"s in advance
    Ecutools is distributer for this tool.
    Experience from me in here , no problem and 100% ok without problem .
  15. The Following User Says Thank You to brend For This Useful Post:
    rafal (18th May, 2023)
  16. #13
    rafal's Avatar
    UK - PL
    Quote Originally Posted by brend View Post
    all correct
    i am using this tool as well - never gets any issues
    need help
    now my goal is to buy xp-005
    who will help?
  17. #14
    Smart66's Avatar
    Dec 2020
    Anyone who had tested it on ECD17(CP14)? As far as I know Original PCM can read/write this ECU without opening in BENCH mode. But I'm not sure for clone versions although many clone versions exist. Which clone version is the best?
  18. #15
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by Smart66 View Post
    Depends of tprot...
    This is thread about Ori product...
