Dont think this has been posted here yet dont know why but with fausto 1.43 it opens Canal Digitaal (19.2?E, Irdeto 2, ID 0000) and TV Globo Internacional Keys (13?E, Nagra 2, ID C102) also has Viasat hack in it
Fausto
(C)MASARE Team-Saoud007
(C)FullDump TM
Special thanks to s62,Snakie,Bordan,Rekordc & KarraKarra
FAUSTO KEYS EDITOR/EMULATOR/LOGGER/CLIENT/SERVER
Installation: not needed to uninstall previous version, just run Fausto V1.XX setup.exe
Fausto Emulator compatibilities:
*XML file to be compatible with Fausto Emulator MUST include cryptoworks Cardkey (06)
This keys used in internal by diablo cam emu
If the CardKey (06) not include you'll can't decode cryptoworks with Fausto Emulator
CardKey (06) added on Keys.bin has no effect under diablo cam emulator
*Include Betacrypt Tuneled Nagra 2 Providers
*Include ECM IV & ECM Seed keys under Irdeto2 Coding System
CS Cards Client supported:
CCCam (TCP)
Newcamd (TCP)
RadeGast (TCP)
Camd35 (UDP cs357x)
Camd35 (TCP cs378x)
Camd33 (TCP)
Gbox client (localhost only, default ports)
Twin Protocol (Serial)
CS Cards server supported:
Newcamd (TCP) & EMM Support
RadeGast (TCP)
Camd35 (UDP cs357x)
Camd35 (TCP cs378x)
Camd33 (TCP)
Support:
- Ethernet (linux box, diablo wifi,...)
- SSSP/HSIC/TM Share/CSC (Serial)
- Season Interface (Cams/box Readers)
- Diablo Wireless (base unit)
Main Functions:
- Emulator
- Logger
- Net client
- Card server
- Cards support
- DVB Plugins (without pctv card)
Version 1.43 (15/03/2010)
- Editor
Modele.xml modified
- Emulator
*Settings files:
FeSettings.ini modified com parameters about season removed
Season.ini added com paremeters for each emulation (Irdeto,Seca,Viaccess,Cryptoworks,Conax)
To keep compatibilities with previous version FE use default settings
Report To Fausto & Season INI File.txt for more details
To create default settings file delete existing one, open emulator window and the new one will be created
*Serial:
- Added CSC ECM protocol support, 6 versions (Now avalaible SSSP/HSIC/TM Share/CSC ECM)
Tested with version:
* Titanium /technocam
* Tiger t6
* Starsat
* Dreamsky
* GlobalStar
* Technosat
Added settings file for named CSC_Cas_Datas.cfg (folder ..\Fausto\Serial\)
Settings file can be edited via tab SETUP
Choose CSC_Cas_Datas.cfg on file list
Press OPEN
Made changes
Press SAVE
Usefull only if ECM not comes from box, it others case NOT required
*Server:
Newcamd: Irdeto EMM code improved
Log File: can be produced without ECM Debug ON
*Client:
-Added possibility to set Connection Max delay
Report to file FaustoClients Example.cfg dor syntax & example (Folder Fausto\Emu\CardClient)
-Added Twin protocol
For client definition report to FaustoClients Example.cfg on folder \Fausto\Emu\CardClient
For more informations read file Fausto & Card Client.txt
Joined file twin_cache.cfg (Folder Fausto\Emu\CardClient) with somes channels example, add your own
-CCcam:
Accruate compatibilities with Nagra3 provider (specially with card read by Newcs)
Added default provider zeroed when only caid defined for a card
-Log File: can be produced without ECM Debug ON
*Cards:
TNTSat Default AES key added if not set on Cards.ini file
Sky Ita card fix
*Setup:
Added posibilities to edit file
CSC_Cas_Datas.cfg
twin_cache.cfg
Include syntax definition
*Language file:
Added [Strings] datas
Added Russian language file thanks to the author
Special Thanks to:
JKF Intersat Forum for all support give to our tools.
All guys for language files & translation:
MagicTrance, superseeder, sYgNaL, mcolaciuri, Seti72, Alaancee, Jogo1967, GarField57, Claudio_LDN, S62, Professor Moriarty, Twister, Stauffie, Anunaki.
Enjoy.
fausto 1.43
h**p://www.megaupload.com/?d=WMOFZVL8
Also load this key file from link below
h**p://www.megaupload.com/?d=5FIP30C9
Bonus: Canal Digitaal Irdeto2 worked
Worked ONLY under Fausto
C+ NED (Ird2) Fausto server & internal emu
1.Open Emulator window
2.Under Monitor Load Keys.bin
3.Side client create a connection to fausto server
4.Under FaustoServers.cfg create server line access & save changes
5.Clic on Tab Manager
6.Press Load
7.Press Start
Channel will be decoded
Example with Newcamd line:
1.Client N Line (CCcam.cfg) -> N: 192.168.5.11 18000 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14
2.FaustoServers N Line -> N: 192.168.5.11 18000 0102030405060708091011121314 {0622/000000}
U: dummy dummy
Latest Canal Digitaal NL Keys (19.2?E, Irdeto 2, ID 0000)
Worked ONLY under Fausto v1.43
16/03 Active key 02
0622:000000:02:02:[E32EB7E21DDBBB3BD76C19533B1E30C6]; C+ Nederland (19?E)
17/03 Active key 03
0622:000000:03:02:[A65E34C26F112F250CB0CCF7B0FA8A69]; C+ Nederland (19?E)
How to update keys file
Run Fausto
On Main Menu clic on File
Clic on Load Keys File (select & open file Fausto_Multicam_Keys.XML)
Double Clic on Coding System Irdeto 2 to expand keys list
Select Key wanted (on screenshot joined key 02)
Enter or copy/paste new value for key
Clic on File menu
Clic on Save keys File
Changes can be done when emulator running, in this case under Tab Monitor, just reload fresh keys.bin
Hope it helps
MASARE Team
