Results 1 to 13 of 13
    eprst's Avatar
    Jul 2011
    Russia
    Default Renault Megane 4 1.5DCI ADBlue OFF
    Hello friends. It is necessary to disable ADBlue Renault Megane 4 1.5DCI control unit MD1CS006.
    I appreciate your decisions
    THANKS + REP if I help you
    S0nda's Avatar
    Nov 2021
    Reading....
    Quote Originally Posted by eprst View Post
    can help u within 30 mins if no one helps u.
    Autotuner Master - FLEX Master - DFOX Master (DFBtechnology) PCMflash 1.3.8 - VCDS hex v2 - Scanmatik 2 pro - Launch - Odis
    "clones" -> Ktag - Kess v2 - Mpps v22 - FGtech - Inpa -
    WinOLS 5
    IF helped! Press "Rep & Thanks"!
    pataroucci's Avatar
    Jan 2014
    renault megane4 scr clos
    pataroucci's Avatar
    Jan 2014
  5. The Following User Says Thank You to pataroucci For This Useful Post:
    eprst (28th May, 2023)
    eprst's Avatar
    Jul 2011
    Russia
    Quote Originally Posted by pataroucci View Post
    I try and report
    ps : what sensors need to be disconnected?
    eprst's Avatar
    Jul 2011
    Russia
    The car went fine, but after the test drive, 2 errors appeared: DTC253F29 and DTC164264
    check lamp is on
    how to fix?
    Jun 2020
    check lamp is on
    how to fix?
    Buying the file. The web is full of tuners and sites that sell files. Simple
    File service, Custom Remapping, stage 1 & 2 dyno tested.
    Petrol + Diesel
    Adblue dpf egr Only tested working solutions.
    Use thanks and Rep if my help was helpfull.
    eprst's Avatar
    Jul 2011
    Russia
    There are no adblue errors now and the car is driving normally
    Maybe need to remove the DPF?
    Adblue+DPF off?
  10. #9
    Dec 2020
    Adblue+DPF off?
    No, it's possible to remove only SCR system.
    Unless you also had problems with DPF/EGR with original file.
    ECU-IMMO-Dash-Airbag Solutions
    VAG Immo Transfer Solutions
    FRF/SGO/ODX/SOX <--> BIN Conversion
  11. #10
    pataroucci's Avatar
    Jan 2014
    Default DTC OFF
    DTC OFF OKK
  12. The Following User Says Thank You to pataroucci For This Useful Post:
    eprst (30th May, 2023)
  13. #11
    Mar 2016
    Sweden
    Default ADD OFF
  14. #12
    eprst's Avatar
    Jul 2011
    Russia
    DTC OFF OKK
    After writing the file, there are no errors and the car drives normally. now the car has an error DTC200292 - DPF system faulty,
    I need help to remove Dpf or DPF+Adblue
  15. #13
    Jun 2020
    There are no local tuners in Russia?
    Petrol + Diesel
